4200 Instrument Cluster Repair?
/ 4200 Instrument Cluster Repair? #1
arrabil
Veteran Member
Winterstown, PA
JD 4200 & X475
Howdy.
Anyone know where to send my instrument cluster to get the gauges repaired? Local dealer only wants to replace it at $350 in parts. The temp gauge rises from cold to hot within thirty seconds after starting the tractor and the fuel gauge is bouncy and calls the tank empty at 5 gallons though the tank is listed as 10 gallons. The RPM gauge and the lights work fine.
Thanks!
/ 4200 Instrument Cluster Repair? #2
Are you sure it's the panel and not the temp sensor and fuel tank sender. When I bought mine it always read a 1/4 tank. The float had broken off the sender. If they both went bad at the same time could be a bad ground or electrical connection somewhere. I'd start by checking all grounds and electrical connectors.
M.D.
Been through the whole tractor... Its the panel.
