4200 hydraulic issues
   / 4200 hydraulic issues
is there a link to a manual that shows how to work on the rockshaft? and adjust or repair this part that is sticking? Looking at the few parts I found on Ebay, they do not look like the valve on the tractor, so I am assuming that it comes apart to come off?
   / 4200 hydraulic issues #22
Have you looked up this tractor on jdparts.com to see the various parts and their assembly schematics?
   / 4200 hydraulic issues #23
[video] · Low oil level. · Hydraulic stop valve closed. · Excessive load on hitch. · Hydraulic oil too cold. · Hydraulic oil suction screen clogged. 3-POINT HITCH DROPS SLOWLY OR DOES NOT DROP · Rate-of-drop valve closed. · Rate-of-drop valve set too slowly. 3-POINT HITCH DROPS TOO FAST · Rate-of-drop set too fast. · Load too heavy.[/video]
Nother from manual. May/may not help???
Thank you for all of the help, We replaced the shear pin and it works well now. Also soaked the area with pb blaster several times and it worked in and things are moving smooth. total cost of the repair, JD quoted $1500. he spent 0.20 on the shear pin, and about $5.00 on a can of PB blaster.
2016 Nissan Frontier Ext. Cab Pick-up (A56858)
2016 Nissan...
2006 KENWORTH T300 DAYCAB DIGGER TRUCK (A58214)
2006 KENWORTH T300...
New/Unused Agrotk YC-26G Sawmill (A57453)
New/Unused Agrotk...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
