4200 HST Losing Power
   / 4200 HST Losing Power
Hi Egon,
I emptied the radiator fully. I added water to a cool engine and added a bottle of radiator flush. I ran the tractor for about 20 minutes and drained the radiator fully. A lot of crud came out so I waited till the engine cooled and ran some water through it until the water was clear. I then filled the radiator with Prestone pre-dilutted 50/50. Does that sound right? Just to throw something out, could the thermostat be failing?
Thanks for replying so quickly.
   / 4200 HST Losing Power #12
Here is a thought:
Your mower is raised and lowered via a Rear Remote (3rd SCV) correct? The cable that goes from the lever down to the valve is known for sticking. I am thinking your lever is not returning to neutral, and the valve is staying open causing your hydraulics to overheat very quickly by going into relief mode.
Does the lever operate smoothly?
kennyd, The lever seems to be operating smoothly. Is there something that I should be greasing where the cable attaches to the valve? Could the leaky coupler cause the hydraulics to go into relief mode?
   / 4200 HST Losing Power #14
A leaky coupler will NOT cause ant of your problems! Unfortunately, it's not a lack of grease issue. It's just the cable inside the sheath that's gets tight. Just make sure the lever is centered.
kennyd, Thanks for the suggestion. Next time I go out I'll make sure the lever is centered.
Egon, this is a re-post so that my reply to you didn't get lost in the thread.
Well I'm off to push mow 5 acres. :(
   / 4200 HST Losing Power #17
Been there, done that. I wish I were closer to you. I'd be happy to help you out. Sounds like it might be time to get the dealer involved.
I'm changing the thermostat tonight, I'll let you know if it cures my ills.
   / 4200 HST Losing Power #19
Hello,
I had a similar problem and it was caused by debris in the fuel tank. The rust particle would gravitate to the fuel intake after 15-20 mins of operation restricting the flow and run fine after sitting for awhile? Just a thought.Hope it helps?
Matt
Boris1,
What did you do to fix the problem?
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
1997 Ford LT9000 Truck, VIN # 1FDZU90T9VVA11840 (A54865)
1997 Ford LT9000...
Mobile Transformer and Power Substation Portable Power Supply (A55302)
Mobile Transformer...
202479 (A54757)
202479 (A54757)
2012 Freightliner M2 106 Bucket Truck (A55852)
2012 Freightliner...
Electric Mobility Scooter (A54815)
Electric Mobility...
