42" Craftsman Snowblade
   / 42" Craftsman Snowblade #1
ampa
I have a 4' graderblade on the rear 3 pt hitch on my grey market 4x4 ISEKI more or less to add weight over my rear tires which are no longer liquid filled (good reason for this)....anyhow I did not want to break into the tractors hydraulics for the 42" Craftsman.... I mounted this plow on the front using only an electric winch which is a way cheaper route to go other than going hydraulic....I must admit I had problems with this little blade folding up on me last winter...... so this year I doubled chained it and left the one and only spring which is way too weak to use on this 42" blade using this 4 wheel drive ISKI...last year I also had problems of bending and sometimes almost breaking the cable on the winch cable spool....I've since modified this problem by installing a brake light type switch found on most of the older Ford pickups etc....this switch works great and I now have piece of mind as it limits and stops the plow from raising too much and preventing damage....this post is meant for anyone that is using a small light weight plough like the one I have using an electric 12 volt DC winch....this sure beats the manual hand lift I first got when I bought this 42" Craftsman....I still have to get down off the tractor to set the angle as this was also controled by a cable operated hand type lever on the lift and P.I.A lower bar ....take care AMPA......take care......:):):)
Sorry.......I made a mistake and posted this in the wrong section....AMPA
   / 42" Craftsman Snowblade #3
Hey ampa
I just spent today assembling a 42" craftsman blade. The directions were wild and the illustrations insane. Anyhow, here' how it looks, but on an actual Craftsman for which it was intended. Good luck with your project.
Yeah, that's my 'Bota lurking in the back corner. :D
ASCO Transfer Switch (A52377)
ASCO Transfer...
2008 JLG 800S TELESCOPIC MANLIFT (A52705)
2008 JLG 800S...
2025 JMR 78in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 78in Dual...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
New Holland 325 Manure Spreader (A55218)
New Holland 325...
