41XX and 46 Backhoe Subframe
   / 41XX and 46 Backhoe Subframe #1
jrlichina
Platinum Member
Mukwonago, WI
BX2200, '52 8N
I was at the EAA AirVenture and saw the new 46 subframe mounted backhoe. Looks pretty good and appears to allow the use of a MMM when it is not attached. I totally forgot to take pictures, I'm not use to having my camera with me, sorry! They also have new subframe mounts for the 42xx and the 43xx models.
   / 41XX and 46 Backhoe Subframe #2
I am going to EAA AirVenture tomorrow and will be a the show
Friday and Saturday......I will keep an eye for the new backhoe.
   / 41XX and 46 Backhoe Subframe #3
Please do post all you can on the 46 backhoe. Picures would be a big plus. I'm waiting to get my 4110 until I know for certain that the hoe is compatible with the mmm. Thanks.
   / 41XX and 46 Backhoe Subframe #4
Does anyone know of a website where I can find out specs, costs, etc... about this unit? The JD site has no info at all about the 46 backhoe.
   / 41XX and 46 Backhoe Subframe #5
I paid $5800 for the 46 backhoe, subframe and 9" bucket. Freight was an additinal $91. Power beyond kit was $200. Installation was going to be $480, but I installed it myself.
I believe if you build a tractor on the JD website, and pick attachments you can get the details on the 46.
Total weight: 896
Dipperstick digging force: 1250 lb.
Bucket digging force: 2450 lb.
You do have to remove the MMM and 3 point hitch to use the backhoe which takes about 15 minutes. Care has to be taken when removing/installing the 3 point/MMM mount system or you will have to level the MMM when you reinstall it.
It's a decent digger. For comparison, when I picked it up, it was sitting next to a JD47 backhoe. The 47 was quite a bit larger in all aspects...cylinders, metal thickness. The 46 is more of a homeowner unit probably released to help JD compete with the BX22. I have not use the 46 enough to fully evaluate it.
Steve
   / 41XX and 46 Backhoe Subframe #6
Here is how the subframe attaches to the rear of the tractor. Notice how much of the 3 point has been removed.
   / 41XX and 46 Backhoe Subframe #7
The front hangers for the subframe attach to the loader mount.
   / 41XX and 46 Backhoe Subframe #8
The rear mounting support is replaced with a heavy duty mounting support.
   / 41XX and 46 Backhoe Subframe #9
JD4100 TLB.
   / 41XX and 46 Backhoe Subframe #10
That sure looks like a nice set up... /forums/images/graemlins/cool.gif
2003 Ford F-550 4x4 Terex Bucket Truck (A51692)
2003 Ford F-550...
1997 Equipment Trailer, Dual Tandem Axles (A52384)
1997 Equipment...
2003 Evan's Log Trailer, Super Singles (A52384)
2003 Evan's Log...
2012 Subaru Legacy Sedan (A51694)
2012 Subaru Legacy...
2014 Ford F-350 Western Mule 2,000 LB Crane Service Truck (A51692)
2014 Ford F-350...
2015 HINO XJC740 BOX TRUCK (A53426)
2015 HINO XJC740...
