419 loafer hydraulic rebuild?
   / 419 loafer hydraulic rebuild? #1
allyoop
Pensacola
JD 790
Anyone on here ever rebuilt a hydraulic cylinder on the 419 loader? I'm having trouble getting the head driven back far enough to insert the ring compressor. The head drives in just far enough to hide the keeper ring slot.
   / 419 loafer hydraulic rebuild? #2
Need some interpretation to figure out what "head", "ring compressor" and "keeper ring slot" means.
The "head" where the rod comes out making the transition between the rod and the cylinder tube. It doesn't unscrew. It has a keeper ring on the outside, once removed you drive the head into the tube and place a plastic ring in a slot that compresses the keeper ring on the head inside the tube as you pull the guts out.
Ok, got it out. The wipe seal had disintegrated so bad that it allowed some rust to form it the top of the head.
2015 John Deere 8295R (A50123)
2015 John Deere...
Valvoline 6 cases manual transmission oil plus 11 (A53117)
Valvoline 6 cases...
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
New Holland TN65S (A50123)
New Holland TN65S...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A51691)
2015 Freightliner...
