Price Check 4115 Price Check
/ 4115 Price Check #1
Phil2005
Northern Connecticut
JD 4115
Hi, this is my first post. I have been reading the forum for some time now and have to say that the amount of information is tremendous.
We bought a house 2 years ago with 9 acres. The 3 acres around the house is level and wooded. The remaining land is sloping woods with some level areas as you work down the slope. The intended uses for the tractor are as follows, haul cut logs up the slope, dig stumps, trenching for some electrical/water lines to various parts of the property, etc...
We looked at a 4115 that seems big enough while still able to navigate the woods with care. We are looking at a tractor (w/ R4s) on the dealer's lot with a loader and backhoe. Only the loader is not on-site. Does the following price look reasonable? (we are in northern Connecticut)
Item / List / Quote (List price is from JD web site)
Tractor / 16,809 / 14,600
Loader / 2,700 / 2,700
Backhoe / 6,160 / 6,350
Total / 25,669 / 23,650
Thanks in advance!
/ 4115 Price Check #2
Phil,
I think the 4115 is a nice tractor, but I feel it's priced too high against the next step, 4210. If you just go to the Deere website, you will see that list on the two machines favor the 4210, realizing that all the goodies are not included additional control values, etc., on the 4210, but it's a real nice machine and good seller for Deere. If that is the size tractor you want, and don't like the physical size of the 4210, then you might consider the 790, similar size, but tons of power.
/ 4115 Price Check #3
I paid $21,000 for a 4115 w/410 FEL & 46 BH. (This was January of '04) /forums/images/graemlins/smile.gif
/ 4115 Price Check #4
phil,
What dealer is that? You might want to try FVE in Farmington. They've done really well by me over the years. But I agree with JD2210 that unless size is paramount, the next frame size might offer more, although I have heard some rumblings about the 4210 being underpowered. How about a 4310? See we all will have you talked into a 4720 before long! /forums/images/graemlins/grin.gif
/ 4115 Price Check #5
There are a some things not listed in your quote that are included. This is why your list and quote are so close together.
For example:
You need a power beyond kit for the BH.
You need the tall folding ROPS for the BH.
I think there's something else I can't remember.
If you look up the list price, you need to include everything that's on the tractor. I think overall the price is pretty good. I'm not clear on why the BH is higher than list -- although it is a bit of installation work. They may be putting the price of the above items in the BH part of the quote.
When you pick up the tractor, make sure to get the 3pt arms for when you're not using the BH.
Cliff
/ 4115 Price Check #6
Depends on your needs and priorities. I had thought about getting a 4115 for all the lighter work and eventually a (used)full-sized ag tractor for the heavy stuff - but finally elected to split the difference with a large frame CUT.
The 4115 is a very nice but light tractor that is priced close to the 4210 (if there are any of the latter still available - it's a discontinued model) but I see the two as serving different purposes.
One of the most important distinctions between the 4115 and 4210 is the weight. The 4210 is nearly 1000 lbs heavier - and is much more likely to damage your lawn if the ground is soft - where the 4115 should tread much more lightly.
On the other hand, the 4210 (and at that point you might as well go 4310) is a considerably heavier duty, stronger tractor. Different strokes for different folks.
You should expect at least a 15% overall discount from list (but as was mentioned above, to be fair make sure to include
all the small stuff needed). Plus Deere has a multi-implement rebate right now (your loader and hoe should count) good for a couple hundred more dollars.
/ 4115 Price Check #7
The 4115 is the machine I wish I would have got. Some day I hope to trade up to a 4115. I do not agree with going up to a 4210. I just don't like the mid size frames and you can go "one up" to infinity. I also do not like the ehydro so I prefer the 4115 over the 4210. The only suggestion I would make is get some bids to have a contractor do the back hoe work. Here $1000 buys a lot of work so it's very hard to justify a BH for home use at nearly 7k with taxes. The other prices are better than the quotes I got on a 4115 with FEL two years ago ! /forums/images/graemlins/wink.gif
/ 4115 Price Check #8
I would have to agree with Dave. If you are looking at a lot of stumps you will save a lot of wear and tear on the tractor and could buy so many other fun implements. If you get the right equipment in there you could do in hours what may take you months to do.
Btw, I too would love to have a BH..
jeff
/ 4115 Price Check #9
As mentioned, the 4210 is larger and in part for my suggestion of looking up aside from price is the fact you only mention real work items, i.e., loader and backhoe and I suspect you would really enjoy have a larger frame machine if your going to get nasty with a backhoe.
/ 4115 Price Check #10
Hello,
Just wondering what size of bucket are you getting with your BH? I'm also shopping right now and the 9" is what comes with the 46 BH but you can get a 13", 16", 20" or 24" for additional money... 9" seems to be a bit narrow for my taste... I'm planning to use the BH mostly to dig out tree stumps.
Hypernix
/ 4115 Price Check #11
Hypernix - I have a 13" on mine and after very limited use this winter am thinking I should have gone with the 16". I'm trenching with it and there's plenty of power for ripping thru rocks & roots, I'm moving very little material with each scoop. But it sure beats a shovel or post hole digger!
-Norm
/ 4115 Price Check #12
I have the 9" and 13" buckets for my 46 hoe. For the cedar stumps we are taking out right now the 9" bucket works pretty good. I am glad that I also have the 13" bucket. /forums/images/graemlins/smile.gif
/ 4115 Price Check #13
I have the 13" bucket on my 46BH. I was talked out of the 9" bucket by the members here, and I'm glad I was. It means my trenches are slightly wider than I'd intended, but the 9" bucket doesn't have teeth and carries very little dirt. People also pointed out that the 9" will sometimes not release the dirt requiring you to get off the tractor with a pike and knock it out. Larger than the 13" and I would have had difficulty with the smaller stumps I spent the last summer removing. It turned out to be the perfect size for my purposes. If I was digging holes, I'd want a larger bucket. Your mileage may vary.
Cliff
/ 4115 Price Check #14
</font><font color="blue" class="small">( but the 9" bucket doesn't have teeth... )</font>
The 9" bucket that came with my hoe has two teeth and the 13" bucket has three...
/ 4115 Price Check #15
</font><font color="blue" class="small">( The 9" bucket that came with my hoe has two teeth and the 13" bucket has three... )</font>
Oops, sorry. The picture the dealer showed me of the 9" had no teeth. He recommended the 13" and swapped it out for me without charging extra. I wonder if they changed the design somewhere along the way, or if there is more than one version of the 9" bucket?
Cliff
/ 4115 Price Check
I appreciate all the responses, they are helpful. To address some of the comments:
The 36 month 0% financing lead me to look at the 4115 and the size is right for what we need. One advantage of having no past tractor experience is at least we will not know what we are missing vs another model.
I did go back and re-price it on the JD site making sure to include all the items needed and the total list price comes to $27,197 vs the original calculation of $25,669.
At some point in the future we may use it for mowing so the lighter weight vs something like the 4210 is a consideration.
The trade-off on the price of the backhoe vs the cost of hiring someone to do the work is valid. The financing offer makes it a little easier to go for the backhoe. In the end I have to fall back on a higher authority, my wife said "What is the sense of getting a tractor if it doesn't have a backhoe?" How can I argue against that?
As far as bucket sizes, loader = 53", backhoe = 13".
I did get a quote from the dealer mentioned by JDFANATIC and they were $200 less. If the tractor needed warranty work at the dealership they would transport it no charge, other dealer would charge.
Thanks again for the responses.
/ 4115 Price Check #18
Phil,
Glad to see you have reasoned and worked things out. Post some pics when you get it! /forums/images/graemlins/cool.gif
/ 4115 Price Check #19
Phil,
Excited for you do stay in touch..
Oh Yeah Regarding:
"In the end I have to fall back on a higher authority, my wife said "What is the sense of getting a tractor if it doesn't have a backhoe?" How can I argue against that?"
Could you please have your wife give mine a call /forums/images/graemlins/grin.gif
ATTENTION PLEASE READ (A64127)
ATTENTION PLEASE...
2004 Jeep Wrangler X 4x4 SUV (A61574)
2004 Jeep Wrangler...
2017 Chevrolet Tahoe SUV (A64557)
2017 Chevrolet...
2003 Dodge Ram 4x4 Ext. Cab Pickup Truck (A59230)
2003 Dodge Ram 4x4...
2010 John Deere 4720 (A64126)
2010 John Deere...
1985 GREAT DANE 45' SLIDE AXLE FLATBED TRAILER (A59911)
1985 GREAT DANE...
