4110 wont start just rapid clicks
   / 4110 wont start just rapid clicks #21
I'm (Joe1shoe) a JD 4710 owner who came in the thread late. My tractor quit on me suddenly on a refuel stop afer working all day. I was searching for a resolution and found this thread. The ideas were all good. But no one ever said what fixed the 4110 owner's issue. So I tried two of them at once to get back to work fast.
Thought I would let you know what my fix was because I don't ofen see a battery go from working great to shorting out with one turn of the key. And I'd like to know what worked for the 4110 guy. Seems like an unfinished story....
   / 4110 wont start just rapid clicks #22
I
I've had that happen several times, always with house brand batteries. Due to weak or shoddy construction, the heavy current blows an internal connection just like a fuse going. In some cases, a volt meter will show a full charge under no load conditions, but a load test will fail. That usually means a grid has corroded to the point that it partially collapsed and can no longer sustain a heavy current flow.
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2015 FREIGHTLINER...
2022 Kubota U55-5 Midi Excavator (RIDE AND DRIVE) (A50775)
2022 Kubota U55-5...
(APPROX 15) 6" X 2" X 68" TUBING (A54756)
(APPROX 15) 6" X...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
2003 Eager Beaver 50GSLPT (A47477)
2003 Eager Beaver...
