4110 T4 series, pinion needed
   / 4110 T4 series, pinion needed #1
parts2
Mahindra
Looking for part number 16704112010
It's a pinion for the front.
Can NOT find anywhere that is in stock, Mahindra shows out of stock.
   / 4110 T4 series, pinion needed #2
The second time I had a problem with my front diff it wasn't feasible to repair it part by part. I ended-up getting the whole new diff complete for approx. $700 (+/-). Couldn't round up all the parts I needed individually. This was probably 8 - 10 years ago.
The first time I had trouble with it, it was the studs in the carrier that hold the ring gear had broken and I was able to get those and make the repair that lasted a few years before having to replace the diff. Be sure to clean the whole axle housing out super clean before installing your repaired/new diff. I dropped the whole thing out from under the tractor on both repairs to be able to clean/rinse it out with solvent and blow with air. Just 1 single piece of metal or grit can destroy all of your hard work !! Good luck !
2016 New Holland Boomer 47 4WD Front Loader Utility Tractor with Bush Hog BH16-2 (A50322)
2016 New Holland...
2008 MACK GRANITE HOT OIL (A50854)
2008 MACK GRANITE...
Set of Ag R4 Wheels and Tires (A51039)
Set of Ag R4...
197390 (A50459)
197390 (A50459)
2019 RBR Venturi 380 (A51039)
2019 RBR Venturi...
2017 JOHN DEERE  30G (A50854)
2017 JOHN DEERE...
