Ballast 4110 Rear Ballast
   / 4110 Rear Ballast #22
Thanks Stuart,
How many 50 lb plates do you think you could fit in the box? Guess I should have asked that before. Mine is currently filled with sand, about 450 lb. I'd like a little more weight, but don't want to fill it with concrete. Using the 50 lb plates sounds like a good option.
Koby
   / 4110 Rear Ballast #23
My guess is 12 to 15 50lb weights/ The weights are about 1" to 2" thick and 15" in diameter if this gives you any idea. They also make an extension for the ballast boxes that sit on top of the box if you need more room. I do not know why they did not just make the box bigger to begin with but I can guess. The weights are easy to move in and out at 50 lbs. Any heavier and I would be visiting my doctor.
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
2018 Ford Escape SUV (A56859)
2018 Ford Escape...
2022 CATERPILLAR 301.5 EXCAVATOR (A52709)
2022 CATERPILLAR...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2021 Deere 331G (A53317)
2021 Deere 331G...
Agri-X 5' 3pt Mower (A53317)
Agri-X 5' 3pt...
