4110 lift cover adjustment
   / 4110 lift cover adjustment #1
Russo52805
Kubota M59
I finally got all the parts in for the lift cover in and went about installing everything yesterday. I replaced the follower pin all the orings and the lift cylinder ring and oring. Checked the unloader valve (metel ring) and lift valve. The lift would only work before with draft control lever pushed all the way down. Found the the draft control spring was missing going from back of lift cover to square turn buckle in control arm. So that has been replaced as well. Any way the problem I'm having is when I went to adjust the linkage. Draft control first according to FO-31 I can't sorted up the turn buckle enough to get the control valve .03 below the valve bushing. I can't see any other parts that are missing both on the NH site or in manual. Any ideas of what is bent or missing?
Thanks Wes
1972 4110 LCG
DIESEL
SOS
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
(4) 5 LUG GRAND PRIX ALUMINUM WHEELS (A51248)
(4) 5 LUG GRAND...
2013 HYUNDAI VC2530152 53FT DRY VAN TRAILER (A53426)
2013 HYUNDAI...
FAKE (A52472)
FAKE (A52472)
UNIVERSAL WOLVERINE PFF2-13-45W QUICK ATTACH MAST (A51248)
UNIVERSAL...
