4110 JD glow plugs
   / 4110 JD glow plugs #1
klink
Ohio
Ford 660,JD 4110 Hydro - JD 670 gear - 48 Farmall Cub - 51 Farmall H - John Deere 50 - JD X540 JD X580 AC 917 WH 81 Cub Cadet 1541 & 70
The owners manual for my JD 4110 only mentions glow plugs once, containing very little information.
My question is - does my 2004 - 4110 have glow plugs and what is the best way to use them? Since there is no indicator light.
Thanks
   / 4110 JD glow plugs #2
Dick
Refer to the thread concerning 2210 smokes on startup. There was a good discussion on cold starting on the 2210, and I believe it should be similar to the 4110 also.
/forums/images/graemlins/cool.gif
   / 4110 JD glow plugs #3
The 4110 should be the same as the 2210. I knew it had them because of the schematics on JDParts. The dealer said Deere never even told the dealership how the Glow Plugs are activated. They had to figure it out themselves (not in the manual). /forums/images/graemlins/shocked.gif
You have to move your shift lever into high or low range, then turn the key to start (it cant' start but the glow plugs glow). Hold the key there for 20-30 seconds, and let it warm up. Then shift back into neutral, and start the tractor. /forums/images/graemlins/grin.gif
   / 4110 JD glow plugs #4
I was told to cycle the plugs in that manner for only 5 seconds, or so. When cold, the advice was to do two or three cycles of 5 seconds before engaging the starter.
   / 4110 JD glow plugs #5
</font><font color="blue" class="small">( I was told to cycle the plugs in that manner for only 5 seconds, or so. When cold, the advice was to do two or three cycles of 5 seconds before engaging the starter. )</font>
I agree with Pete's method..otherwise burnout can happen when on too long...
Duc
Thanks guys
I will try these procedures the next cold start. I have noticed it takes a little longer to start as the weather gets colder.
I wanted to make sure I was using the glow plugs correctly /forums/images/graemlins/grin.gif
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
2018 Freightliner M2 106 Cab and Chassis Truck (A51692)
2018 Freightliner...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
