4110 hydraulic system "bleeding"
/ 4110 hydraulic system "bleeding" #1
mboulais
USA
2004 Mahindra 4110
I recently tore the hose off the back of the hydraulic filter on my 4110. I removed the filter housing while I straightened the bracket it sits on. Everything is back where it belongs (more or less) and I filled the oil back up, but it sat for 3 days with no oil and it appears the pump needs to be primed. I bled the filter canister, but I am apparently not getting oil to the loader. The 3pt and aux valve are both working though. The system is supposed to be 9.77 us gallons (not incl loader), I have put in about that much, but don't see any on the stick yet. Anyone run into this changing their hyd/tran oil?
/ 4110 hydraulic system "bleeding" #2
Marcel
The oil level on the transmission dip stick is hard to see I would check again. Also if your 3PH is working that means your getting pressure to the loader valve and your 3PH is being fed by the power beyond on the loader valve. The problem has to be at your loader valve if the loader will not operate. I'm not sure what could be wrong at that point but the service rep will in today and I will ask him.
I didn't think of it last night, but the pressure relief valve has stuck open on me before while back dragging before. I will check that tonight.
/ 4110 hydraulic system "bleeding" #4
Marcel
I discussed your problem with the Mahindra service rep and we concluded that your problem must be in the loader valve pressure relief. It sounds like you have already come to that conclusion. Let us know what you find.
All set, It was the pressure relief on the loader valve. The tractor has been recovered from the woods, and is resting comfortably in the barn.
/ 4110 hydraulic system "bleeding" #6
I punctured that little hose when I had less than 50 hours on my tractor. Until you get the hose fixed and the hytrans back into it you aren't going anywhere.
/ 4110 hydraulic system "bleeding" #7
Did you have full pressure at the 3ph and remotes? Im asking because it seems on my 7520 that the FEL relief also acts on everything fed beyond the fel valve. Maybe yours is different tho - - is it HST?
larry
/ 4110 hydraulic system "bleeding" #8
I ran over a 12" concrete block while clearing a lot a couple years ago and bent my bracket all over too. I didn't rip the hose off but it kinked it so bad I lost my power steering. Seems to me that circuit would only affect the p/s except for the fact it drains the trans. case if a fluid leak occurs like yours. The internal pump is what supplies all the other hydraulics on the tractor and doesn't require that filter circuit to operate. Just the operation of the p/s system draws fluid thru that filter which effectively filters for the whole system since they use the same resevoir. The fluid has always been very difficult to see on the trans. dipstick - have to hold it in just the right light to see the level on the stick. Mine has always taken the 10 gallons to refill on a complete drain.
/ 4110 hydraulic system "bleeding" #9
I think it holds between 11 and 12 gallons altogether. Obviously, when you drain and change the fluid you aren't going to get all of it out.
larry
It's not HST. Power steering, remotes and 3pt work ok when the pressure relief on the loader sticks open. Just loose loader functions.
2017 Lincoln MKC Multipurpose Vehicle (MPV), VIN # 5LMCJ2C95HUL50284 (A65563)
2017 Lincoln MKC...
2012 HINO 268 4X2 S/A BOX TRUCK (A59914)
2012 HINO 268 4X2...
2006 International 4200 2,000 Gallon Water Truck (A64553)
2006 International...
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
Conveyor Belt (A64194)
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A65563)
IMPORTANT PLEASE...
