4110 hyd problem
/ 4110 hyd problem #1
cajunmike
with the bush hog on the tractor it goes up good but when i try to put down its very slow . i checked the speed control its ok . this problem is with engine running. with engine not running it goes down like it should and i can control the speed with the lever.thanks
/ 4110 hyd problem #2
Close the speed control completely, then open it all the way up (for fast downward travel). If there is some restriction in that valve this might free it up. Does it do it all the time, or just with the hog on?
/ 4110 hyd problem
ITS LIKE THAT ALL THE TIME- THANKS
/ 4110 hyd problem #4
Have you tried moving the draft control lever?
/ 4110 hyd problem
I TRIED MOVING ALL LEVERS STILL NO LUCK . WILL TAKE APART IN A FEW WEEKS WHEN I FINISHED WORKING THE TRACTOR. THANKS FOR THE REPLY
