4110 fuel problem
/ 4110 fuel problem #1
mike4110
Shannon, MS.
Mahindra 4110
I have a 2004 model 4110 that isn't getting fuel to the filter. My question is, is there a strainer or filter in the fuel tank itself. Looks like it might be a pain pulling that tank off. Would hate to take it off for no reason.
/ 4110 fuel problem #2
Can you look into the tank? Perhaps there is sediment in the bottom. If so, you will have to flush it. I don't know if you will need to remove it to do so. The manual for my Mahindra recommends periodic draining. However with 585 hrs. on mine, I've never drained it.
/ 4110 fuel problem
Thanks for the replies. I think i will try blowing back through the fuel line to clear the blockage.
/ 4110 fuel problem #5
I would disconnect the line from the tank to the filter on both ends. Then I would blow it out. If the blockage is in the line, you don't want to blow it back into the tank.
/ 4110 fuel problem #6
Om my 4310 there is a position on the valve to drain water. That would let you know if there is and fuel coming through the valve at the bottom of the tank.
HEAVYEQUIPMENT PRESSURE WASHING PARTS (A68842)
HEAVYEQUIPMENT...
PALLET OF FUEL TANKS (A68842)
PALLET OF FUEL...
1989 CUTOM 15T-100 EQUIPMENT TRAILER (A66091)
1989 CUTOM 15T-100...
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A67714)
2013 ORTEQ ENERGY...
2016 WIRTGEN W150CFI MILLING MACHINE (A65056)
2016 WIRTGEN...
