4110 frt axle nosiey
   / 4110 frt axle nosiey #1
rickard45
coldwater, mississippi
axle makes clicking rubbing sounds, fluids all full, 4wd works fine. could it be something easy?
   / 4110 frt axle nosiey #2
Check the bolts that bolt the front axil to the tractor frame. They have been know to loosen and when the axil shifts a little the drive shaft will act like what you are explaining. Check this soon before things get worse.
thanks for the info, the bolt were loose a year ago or so. will check to see if it has shifted, i have done a lot of dirt work on a 30 by 40 shop that i built.i rased the the tractor with the loader and spin the tires the the whole axle assy sounds nosiey is this normal
   / 4110 frt axle nosiey #4
When mine is all in good condition there is very little noise when turned by hand slowly. You can always hear a little gear mesh and/or a little slop if rocked back & forth but no growling or grinding. This is all assuming you're not trying to spin the wheel at 30 mph - 3 times as fast as it's supposed to be going. The drivetrains are much more forgiving of minor wear & tear simply because of the speed that they operate. I've had my share of front axle problems, you can review my posts over the past 4 years.
   / 4110 frt axle nosiey #5
We have a noisy 4110 in the shop now and it had a few teeth missing on the front ring & pinion . Make sure you use enough counterweight when using the front loader because you want the rear axles doing at least 75% of the work not the front .
Quick Attach Stump Grinder (A50514)
Quick Attach Stump...
Kubota F3990 72in Commercial Mower (A50322)
Kubota F3990 72in...
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
6' King Kutter 3 pt Disk (A50515)
6' King Kutter 3...
KJ 7'x20' Metal Gate (Deer) (A50121)
KJ 7'x20' Metal...
