4110 FEL Bucket creep
   / 4110 FEL Bucket creep
Thank you for the info, sounds like I'll just have to live with it unless it gets worse. It has been about the same degree since I bought it 300 hours ago.
   / 4110 FEL Bucket creep #12
On my 4110 which has a little over 150 hours now, when I go to back drag with the bucket slightly in a dump configuration seems to want to float level with very little dirt resistance and not stay in the dump configuration while moving backwards, but will hold its configuration in a upward curl, or slightly dump configuration while moving forward. Is this normal wear? Or are my cylinders worn. Worked like a champ till now.......... Mlitt12345
   / 4110 FEL Bucket creep #13
MLITT:
You are seeing cavitation when it does that. Easiest way to fix that is to operate at higher RPM's to get more gallons from the pump.
2025 CFG Industrial TK35R Mini Track Loader Skid Steer (A50322)
2025 CFG...
2012 Audi Q7 (A50324)
2022 Western Star Tri Axle Dump (A47384)
2022 Western Star...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
200 Gallon 3-point Sprayer 30ft Boom (A52128)
200 Gallon 3-point...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
