4110 FEL Bucket creep
   / 4110 FEL Bucket creep
Thank you for the info, sounds like I'll just have to live with it unless it gets worse. It has been about the same degree since I bought it 300 hours ago.
   / 4110 FEL Bucket creep #12
On my 4110 which has a little over 150 hours now, when I go to back drag with the bucket slightly in a dump configuration seems to want to float level with very little dirt resistance and not stay in the dump configuration while moving backwards, but will hold its configuration in a upward curl, or slightly dump configuration while moving forward. Is this normal wear? Or are my cylinders worn. Worked like a champ till now.......... Mlitt12345
   / 4110 FEL Bucket creep #13
MLITT:
You are seeing cavitation when it does that. Easiest way to fix that is to operate at higher RPM's to get more gallons from the pump.
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
Case IH 3408 8 Row Corn Head (A52349)
Case IH 3408 8 Row...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
2011 Chevy Avalanche (A50324)
2011 Chevy...
CATERPILLAR 325FL EXCAVATOR (A51242)
CATERPILLAR 325FL...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
