4110 - Did I overfill my transmission?
   / 4110 - Did I overfill my transmission? #1
grimmwit
Hello all -
Recently, I had noted that the hydrostatic transmission on our 4110 tractor was whining a lot. We have about 75 hours on it.
I checked the fluid level using the technique described in the manual (run until warm, park on level surface, wait an hour, and eyeball the window on the back of the tractor). No fluid was showing. I confirmed this by checking the transmission dipstick as well.
Per the manual instructions, I slowly added fluid until it showed 1/2 way up in the window. As I've written this, I've realized I didn't check via the dipstick.
Anyway, to test, I ran the tractor around the yard for about 5 minutes, then parked on the driveway again, planning on checking the level again. When I came back, I noted a small puddle of liquid on the ground, underneath the rear axle transmission area. I crawled under, and see oil coming down the left side of the transmission from up high - I couldn't see the exact source.
All that said - back to my question.... Is there some sort of an "overflow" drain or hose that could be releasing fluid because I overfilled? Or do I likely have a leak - either a problem, or one that I induced by possibly overfilling?
It was getting dark and rainy, so I haven't had a chance to further evaluate my work. I'll check the levels again tomorrow.
Any hints / tips or suggestions gratefully accepted.
Thank you in advance for any assistance offered.
Grimmwit
   / 4110 - Did I overfill my transmission? #2
welcome to TBN, I can't say if you over filled it or not but I remember when I did my 50 hr. service on my 4110. I had someone watching the sight glass as I poured the fluid. As soon as they saw the fluid in the sight glass I stopped pouring. By the time it all ran down into the tranny It filled the entire sightglass.However when I checked the dip stick it was right on the full mark.
   / 4110 - Did I overfill my transmission? #3
I do not think there is a overflow, But make sure that the 3PH and the FEL are lowered all the way before you check the level.
Oh, and welcome to TBN:D
Thanks for the input and suggestions.
I had my wife pull the tractor out yesterday and check the levels again, with the bucket and 3 point mount down - it's definitely over-filled.
I' hoping that perhaps the leak was the result of fluid exiting the dipstick hole somehow.
I'll read up this evening on what I need to do to drain the fluid. Hopefully I didn't do any damage......
Grimmwit
(and thanks for the kind welcome as well - I hung out here a bit when I first researched and bought the tractor, but haven't been back in some time)
   / 4110 - Did I overfill my transmission? #5
Draining should not be hard, but messy for sure!
Pleas let us know how you make out...
1111-A (A54756)
1111-A (A54756)
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB 3 Ton Crane Service Truck (A55788)
2014 Ford F-550...
Skid steer auger plate (A50322)
Skid steer auger...
6' 3Pt. Blade (A53316)
