4110, Coincidence or not...
   / 4110, Coincidence or not... #1
4runner
WNY
JD 322, JD 4110
The question...
JD 4110. I don't have the service manual or a schematic for the tractor. My question is, does depressing the switch activate a relay or other circuit that may put a low current drain on the battery even when the tractor is "off"?
The back story...
First, I know I am due for a new battery based on the fact that the tractor is a 2002/2003 model, and I believe the battery is original. But the battery has not given me a bit of trouble until...
...I got tired of having the engine killed each time the seat was unweighted. This happens when my petite wife has to move forward on the seat to reach the pedals, or I get off the tractor to load something in the bucket without putting it in neutral...
...so I took a piece of light gauge sheet stock, placed it over seat safety switch and its mounting bracket and zip tied it in place. The result is that the switch is always depressed as if someone is sitting on the seat...
A week and a half later, the battery died. Coincidence? (tractor was not operated for that period.)
   / 4110, Coincidence or not... #2
It is just a coincidence...there is no voltage in that circuit when the key is OFF.
Your battery is toast-you are lucky to get that much time out of it...hopefully it was not leaking like almost everybody else's has causing damage....
   / 4110, Coincidence or not... #3
My battery is good....but my wife is somewhat overweight.....Coincidence or not?;)
Thanks Kenny. That's what I thought... The timing was strange. The battery is fading fast... Yesterday it was fully charged... today pretty much dead.
Time to pick up a new one.
   / 4110, Coincidence or not... #5
I had to replace the battery on my 2004 4010 this year.
Ralph
   / 4110, Coincidence or not... #6
Fast Pauly;
Either your wife has a great sense of humor...... or you like living on the edge. Even when I'm kidding I get the grandma eye. Good Luck !!!!!!!!!
(16) SINGLE AXLE FENDERS (A54756)
(16) SINGLE AXLE...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
Behlen 150 Gallon Premium Stock Tank (A55218)
Behlen 150 Gallon...
TRAILER AXLE (A54756)
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
BELSHE DT-235 (A53843)
