4110 60MMM
/ 4110 60MMM #1
DGB
Boonsboro, Maryland
Deere 4110 HST
Just took delivery of my 4110 with 410 loader and 60" MMM. I notice something strange that the dealer is going to look at tomorrow. Back by the 3PH where the support arms for the 60MMM attach, the connecting pin has lots of play and can actually rub the inside of the tires. After only .8hrs there is a noticeable rub mark on both tires. Anyone else seen this? I can't believe this is normal.
Thanks in advance,
Doug
/ 4110 60MMM #2
It is not normal. It could be that the assembly is installed improperly or that it is bent. The assembly is a dealer-installed option so he should be able to take care of it, and perhaps have a talk with his technicians. That tractor should have never left the shop if it would have been inspected properly.
/ 4110 60MMM #3
This was a problem with the 60" MMM on my 4110 also. Turn the pins so the head is outboard and the retaining clip inboard. Then put some washers between the inboard side of the arm and the inboard fork. This will keep the head of the pin further away from th tire. I know this is a common problem with the turf tires, is it also a problem with others?
I think Deere had some junior engineer design the whole MMM mounting system, it is kinda kludgy.
/ 4110 60MMM
Thanks for the quick responses. I see how the washer idea would work, but for what I paid I am not sure I am going to accept this solution, at least not quietly. I will post an update after the dealer stops by to have a look.
/ 4110 60MMM #5
I can't take credit for the washer idea as that was suggested by my dealer's senior mechanic. He says it is a common problem.
/ 4110 60MMM #6
I have about 3/8" clearance on each side with turfs. There is a washer installed in the fashion described by JClark, but I would still insist your dealer complete a proper installation just in case the brackets are bent a little, and in case something happens after the adjustment (who ya' gonna' blame?).
FWIW, I intend to remove my assembly during off-season and when I have heavy work to do in the brush. The assembly just hangs down too far for my comfort and common sense.
/ 4110 60MMM #7
Can the rear wheels be flipped to a wider position? With the Loader, you might want that anyway.
- Rick
/ 4110 60MMM #8
Hi Guys,
I have a similar machine (4100) but I dont have any MMM but
I did have a 513 rotary cutting for a small period of time.
I had some clearance issues with the R4's and the 3 Pt arms.
The easiest solution was to switch the rear tires between left and right and reverse them ( valve stem inside). This gave more clearance & wider stance overall - it was noticably more stable. The turfs are bigger than the R4's but I suspect it should help you guys as well? Most likely you already knew about this or have done it?
Duc
/ 4110 60MMM #9
The offset on my 4110 with turfs is mounted inboard (valve stems inboard). I could see where R1s would fit with the offset outboard but I didn't think R4s would fit that way.
/ 4110 60MMM #10
</font><font color="blue" class="small">( The offset on my 4110 with turfs is mounted inboard (valve stems inboard). I could see where R1s would fit with the offset outboard but I didn't think R4s would fit that way. )</font>
If I understand you correctly - I have the R4's mounted right now with the valves inside ( reversed between left and right) they fit excellent on the same machine as the 4110 but its a 4100....the turfs on these machines are bigger ( wider & taller) than R4's so if you can reverse Turfs, you can reverse R4's no problem...R1 are skinnier than either of these two types.
Duc
/ 4110 60MMM
Dealer just finished his visit. Checked everything to make sure nothing on the 60MMM mounting hardware was bent or out of place. Everything OK. His only solution to fix this configuration was the washer trick mentioned by JClark. Something they have done in the past but forgot on mine. He said they have not encountered any problems with the 4110 rear tires due to these pins rubbing.I have the 31x13.50 turfs in the widest setting. He is willing to swap tires to R4s, take back the deck or entire tractor, whatever it takes. I have no doubt my dealer will handle any future related problems, so I will probably live with it. Just a poor design for what appears to be an otherwise excellent machine.
Doug
/ 4110 60MMM #12
The rear turfs on a 4110 won't fit reversed, that is offset out (valve stems outside).
DGB
Sounds like you got a great dealer and I think you will be happy with the 4110.
Your tasks will define whether R4s would be appropriate. I put a lot of time, effort and money in my 2 acre lawn so I want tires that will be as gentle as possible on the turf. While I use my 4110 for all kinds of stuff, it is primarily a **** big lawn mower.
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
2021 KENWORTH T680 6X4 T/A  SLEEPER TRUCK TRACTOR (A59912)
2021 KENWORTH T680...
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
Dodge Charger (A56859)
2002 WACKER RD25 ROLLER (A59912)
2002 WACKER RD25...
