4110 3pt hitch measurement needed, please
   / 4110 3pt hitch measurement needed, please #1
2nstonge
North Bennington, Vermont
JD 4110 w/HST
I ordered a CCM tiller yesterday (& a landscape rake, too), so that the good folks at CCI can cut the PTO to the correct length & ship everything I need the measurement from the base/stub of the rear PTO drive to the midpoint of the centerline of the lower draft links mounting point - draft links must be level in the horizontal position & at a 26" spread.
I took delivery of the 4110 in December, the BH was attached & I'm just realizing the dealer didn't leave the 3pt hardware or the ballast box! I must've been too excited to notice. I've had no reason to remove the BH until now & I can't connect with the dealer until Saturday...any help would be great!
Thanks much, -Norm
   / 4110 3pt hitch measurement needed, please #2
I measured my 4010 this afternoon. It should be the same as the 4110. It was 21 3/4" from the end of the PTO to the mid point of the drawbar between the lift arms with the drawbar near horizontal. The drawbar is 26" wide.
Ralph
   / 4110 3pt hitch measurement needed, please #4
Hello,
Don' knowt if you still need some measurements, I took the following on my 4110.
From the end of the PTO shaft on the 4110 to the end of the lift arms I had 22.5"
I also measured the two PTO shaft I use:
Tiller (Bhuller Farm King 60") PTO shaft
Fully expanded = 32"
Fully retracted = 26"
Tiller side of the PTO shaft = 15.5" (attached to a slip clutch)
Tractor side of the PTO shaft = 20"
Snow Blower (Pronovost Puma 54") PTO shaft
When attached to the tractor = 33"
When fully retracted = 29.5"
I also took a few photos and will post them following this post!
Hypernix
   / 4110 3pt hitch measurement needed, please #5
This picture shows the Tiller PTO shaft fully retracted.
Hypernix
   / 4110 3pt hitch measurement needed, please #6
This one shows the PTO Shaft extended...
Hypernix
   / 4110 3pt hitch measurement needed, please #7
This one shows the end of the PTO Shaft that connects to the tractor... It uses a sliding "bucle" Not sure if this is the exact term, but it seems to be more heavy duty than the pin used on the Snow Blower Shaft.
Hypernix
   / 4110 3pt hitch measurement needed, please #8
This one shows the tiller end of the PTO Shaft attached to a slip clutch...
Hypernix
   / 4110 3pt hitch measurement needed, please #9
This one shows the end of the PTO Shaft that connects to the tractor end and which I use with the Snow blower. Notice the pin used to lock the PTO Shaft...
Hypernix
   / 4110 3pt hitch measurement needed, please #10
And finally a picture of the PTO Shaft attached to the tractor and the snow blower.
Hypernix
2017 TRAILSTART 40FT DUMP TRAILER (A52576)
2017 TRAILSTART...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A52748)
2019 Energreen EVO...
2012 Chevrolet Silverado 1500 LTZ Crew Cab Pickup Truck (A51692)
2012 Chevrolet...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
2011 KENWORTH T800 (A52472)
2011 KENWORTH T800...
2016 FORD F550 CREW CAB SERVICE TRUCK (A52576)
2016 FORD F550...
