410B injector pump problem
   / 410B injector pump problem #1
jim22
Ashland
1985 John Deer 410B
Fuel injector pump will not throttle up. Starts and idles fine. But if you try to operate hydraulics. Engine will bog down or even stall.
   / 410B injector pump problem #2
Have you checked for good fuel flow from tank to inj pump?? It's possible the lift pump could be bad.
Yes New pump and filter.
   / 410B injector pump problem #4
Check fuel return line fitting that screws into pump for blockage. Simple test is loosen screws on timing window on inj pump,pry rubber gasket loose,crank engine to see if that makes a difference.
Thanks problem solved.
2018 INTERNATIONAL LT625 (A53843)
2018 INTERNATIONAL...
2012 Mazada 3 Sedan (A51694)
2012 Mazada 3...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
ALTO AMERICAN LINCOLN MPV-60 RIDER SWEEPER (A51406)
ALTO AMERICAN...
2017 Ram ProMaster City Cargo Van (A51692)
2017 Ram ProMaster...
