410B injector pump problem
   / 410B injector pump problem #1
jim22
Ashland
1985 John Deer 410B
Fuel injector pump will not throttle up. Starts and idles fine. But if you try to operate hydraulics. Engine will bog down or even stall.
   / 410B injector pump problem #2
Have you checked for good fuel flow from tank to inj pump?? It's possible the lift pump could be bad.
Yes New pump and filter.
   / 410B injector pump problem #4
Check fuel return line fitting that screws into pump for blockage. Simple test is loosen screws on timing window on inj pump,pry rubber gasket loose,crank engine to see if that makes a difference.
Thanks problem solved.
2012 Hyundai Genesis Sedan (A51694)
2012 Hyundai...
King Kutter TG72 Rotary Tiller Tractor Attachment (A51691)
King Kutter TG72...
PumpJack Brand Pump Jack (A53473)
PumpJack Brand...
2006 FORD F-250(INOPERABLE) (A53843)
2006 FORD...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
