4100 w/ 410 FEL - how do I "float"
   / 4100 w/ 410 FEL - how do I "float" #1
coloradotrout
Eastern KS
JD 4100 HST CUT w/Yanmar 3TNE74 | JD 300 Lawn
4100 w/ 410 FEL - how do I \"float\"
I read in the manual a technique called "float" or when the FEL is just allowed to sit on the surface with no upward or downward pressure. How do I achieve that? I tried pushing the "joystick" control all the way fwd (lower FEL) and sometimes it works, but not consistently. What's the trick? Does it make sense to use "float"?
   / 4100 w/ 410 FEL - how do I "float" #2
Re: 4100 w/ 410 FEL - how do I \"float\"
I guess you haven't got that part of the manual yet...
Anyway, push the loader joystick forward.....you'll feel a slight hesitation as the stick pushes past a detent. Then you'll be in the float position.
   / 4100 w/ 410 FEL - how do I "float" #3
To get into the float mode, a quick, hard, and fast push forward is needed. Yes it makes sense to use it, like when leveling or smoothing, or pushing snow from the driveway. The loader will follow the contour of the ground.
   / 4100 w/ 410 FEL - how do I "float" #4
There have been several threads on this: yes, most of us newbies have trouble figuring it out. With the FEL about a foot or so above ground, quickly push the joy stick all the way forward and then slightly right when you feel the detent. After you do it a while, you'll be able to do it every time.
It's a great way to run the bucket for snow plowing, to scrape the surface yet not dig into it.
Hope you also have a bucket level indicator. Mine didn't come with it. I mentioned it to the guy who delivered it. The sales person said I should have had it included and sent it out afterwards.
The float on the 3pt is in the middle, for it to float up. If you want it to float over everything, like with a finish mower back there, I think you leave it in the down position.
Ralph
   / 4100 w/ 410 FEL - how do I "float" #5
</font><font color="blue" class="small">( There have been several threads on this: yes, most of us newbies have trouble figuring it out. With the FEL about a foot or so above ground, quickly push the joy stick all the way forward and then slightly right when you feel the detent. After you do it a while, you'll be able to do it every time.
Ralph )</font>
Ralph, why push to the right for float?
Also, the 4100 has position control on the 3PH, it is not the same setup as your 4010.
   / 4100 w/ 410 FEL - how do I "float" #6
As said, full forward on the SCV should put the 410 in "Float". As Ralph says, a foot or so off the ground and a quick full forward push of the lever and you should feel it snap into float as the FEL drops smoothly to the ground. I also use this when parking the 4115. I lift the FEL up a few feet, set the brake, shift to neutral (HST) and turn off the ignition. Then I snap the SCV full forward. This "floats" the FEL down and relieves the hydraulic pressure. Then, pulling back on the SCV and pushing it fwd, back, left, right, relieves most residual pressure.
Any one correct me if I'm wrong but, relieving the pressure this way is a good idea whenever parking (and shutting off) the CUT and should be done whenever you intend to disconnect any of the hydraulic quick connects, such as for removing the FEL. This prevents pressure in the lines from spraying yourself with fluid when you disconnect a line. [NOTE: It is still a good idea to cover any connection with a rag as you disconnect, just in case.]
</font><font color="blue" class="small">( <font color="blue">...push the joy stick all the way forward and then slightly right...</font>)</font>
Ralph...I've never found a need to push to either side, just straight forward, on the 410, on my 4115. May be different on other CUT's...not sure.
Also,
</font><font color="blue" class="small">( <font color="blue">...The float on the 3pt is in the middle, for it to float up. If you want it to float over everything, like with a finish mower back there, I think you leave it in the down position.</font>)</font>
I don't know about the 4100 or 4010, but on the 4115 (as far as I know), there is never any down pressure on the 3ph, other than what force is due to attached implements. IMHO
Tom
   / 4100 w/ 410 FEL - how do I "float" #7
I believe pushing to the right rapidly caused a rapid dump to occur and that there is a detent for that as well. If you go to the right rapidly and down you still end up with "float" occuring. Not sure why though.......I haven't used my loader much this summer, so I am little rusty /forums/images/graemlins/tongue.gif
   / 4100 w/ 410 FEL - how do I "float" #8
Garchib--yes rapid dump is a push farthest to the rigfht, but technically there is no "detent" to keep it in that position. There is some sort of resistance to let you know you have opened up that valve all the way, though Once the float detent is set directly forward--12:00--on all the tractors using the 410 loader it holds the joy stick in place.
I've never heard anything about a slight right push for loader float, nor have I ever heard of a 3-PH not floating regardless of the control position. /forums/images/graemlins/confused.gif
   / 4100 w/ 410 FEL - how do I "float" #9
That makes sense..it is probably my rustiness showing..the funny thing is I use the loader and do not think about it, so to explain it is tough for me. It is kind of like someone asking you for the details of walking, after awhile it becomes second-nature /forums/images/graemlins/grin.gif
   / 4100 w/ 410 FEL - how do I "float" #10
Funny how I never seem to get a fast dump right away when I want it and it always seems to slip directly to the fast dump when I want to feather it. Operator error, for sure /forums/images/graemlins/blush.gif
2005 Caterpillar 430D 4x4 Extendahoe Backhoe Loader (A51691)
2005 Caterpillar...
2024 JOHN DEERE 9R440 LOT NUMBER 78 (A53084)
2024 JOHN DEERE...
1997 John Deere 8100 MFWD Tractor (A53472)
1997 John Deere...
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A51572)
2016 Hino 195h...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
