4100 - is battery serviceable? add water?
   / 4100 - is battery serviceable? add water? #1
coloradotrout
Eastern KS
JD 4100 HST CUT w/Yanmar 3TNE74 | JD 300 Lawn
My 2000 jd 4100's battery seems to be near death. I've charged it a couple times (10A charge and 2A charge), but it never holds for more than a few days. Can I pry off the caps and add distilled water? Or are these suppose to be maintenance free?
   / 4100 - is battery serviceable? add water? #2
Careful of older JD batteries (they leak !!!). Most 4100 owners have replaced their batteries with Optima(s). There are boatloads of threads on this topic if you do a search.
   / 4100 - is battery serviceable? add water? #3
Battery sounds sulphated and shot to me. 5 years is pretty much the life of most batteries if you are lucky.
Or are you sure your charging system is working ok ? What is the voltage accross the battery with the engine running ?
Ben
FRONTIER LR5060 LOT NUMBER 148 (A53084)
FRONTIER LR5060...
EZ-GO Textron Electric Golf Cart (A51694)
EZ-GO Textron...
2008 Nissan Sentra Sedan (A51694)
2008 Nissan Sentra...
1991 INTERNATIONAL WATER TRUCK (A52472)
1991 INTERNATIONAL...
Tradewinds Power Unit (A50120)
Tradewinds Power...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
