40B massey backhoe & bucket need info about AD4.203 diesel engine
   / 40B massey backhoe & bucket need info about AD4.203 diesel engine #1
Burton Mc
Columbia Tn.
tm1500
Anybody out there own one of these about a 1978 year. What would cause an excessive amount of blow by oil out of the perkins diesel engine AD4.203? Tractor runs ok. I have taken the injectors out and put mistry oil & penetrating oil in on top of piston hopeing if it is some stuck rings it may loosen them up. Any suggestions will be appreciated. It has been run without a breather filter for how long I don't know. And I think it had set idle most of the last 10 to 12 years.
   / 40B massey backhoe & bucket need info about AD4.203 diesel engine #2
Could be stuck rings, worn out rings or worn valve stems.
   / 40B massey backhoe & bucket need info about AD4.203 diesel engine #3
"It has been run without a breather filter" This is most likely the culprit. Dirt will destroy an engine quickly, It is critical to never run a tractor without a air filter as they work in a dusty environment. I suspect that you are most likely looking at a engine rebuild. Fortunately Perkins ad3.152 and ad4.203 are some of the cheapest engines to rebuild. However since you have a loader and backhoe extracting the engine for rebuild will be a very time consuming task.
I have taken the injectors out and put mystry oil and penetrating oil on top of the cyl and hope if it is a stuck ring it will free them thanks for the reply
thanks for the reply if it comes to a rebuild I may try it in the tractor
   / 40B massey backhoe & bucket need info about AD4.203 diesel engine #6
You can do a in-frame rebuild on it.
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
2013 Dodge Charger Sedan (A51694)
2013 Dodge Charger...
JOHN DEERE TS LOT IDENTIFIER 138 (A53084)
JOHN DEERE TS LOT...
1838 (A51248)
1838 (A51248)
