40B massey backhoe & bucket need info about AD4.203 diesel engine
   / 40B massey backhoe & bucket need info about AD4.203 diesel engine #1
Burton Mc
Columbia Tn.
tm1500
Anybody out there own one of these about a 1978 year. What would cause an excessive amount of blow by oil out of the perkins diesel engine AD4.203? Tractor runs ok. I have taken the injectors out and put mistry oil & penetrating oil in on top of piston hopeing if it is some stuck rings it may loosen them up. Any suggestions will be appreciated. It has been run without a breather filter for how long I don't know. And I think it had set idle most of the last 10 to 12 years.
   / 40B massey backhoe & bucket need info about AD4.203 diesel engine #2
Could be stuck rings, worn out rings or worn valve stems.
   / 40B massey backhoe & bucket need info about AD4.203 diesel engine #3
"It has been run without a breather filter" This is most likely the culprit. Dirt will destroy an engine quickly, It is critical to never run a tractor without a air filter as they work in a dusty environment. I suspect that you are most likely looking at a engine rebuild. Fortunately Perkins ad3.152 and ad4.203 are some of the cheapest engines to rebuild. However since you have a loader and backhoe extracting the engine for rebuild will be a very time consuming task.
I have taken the injectors out and put mystry oil and penetrating oil on top of the cyl and hope if it is a stuck ring it will free them thanks for the reply
thanks for the reply if it comes to a rebuild I may try it in the tractor
   / 40B massey backhoe & bucket need info about AD4.203 diesel engine #6
You can do a in-frame rebuild on it.
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
UNUSED AGT MXCRT23 STAND ON SKID STEER (A51247)
UNUSED AGT MXCRT23...
Kubota SVL95-2 High Flow Cab Skid Steer (A53472)
Kubota SVL95-2...
UNUSED RAYTREE RABC44-44" ARTICULATING BRUSH CUTTE (A51248)
UNUSED RAYTREE...
THRESHOLD 30" SQUARE OUTDOOR GAS FIRE TABLE (A51248)
THRESHOLD 30"...
