4052M Hyrdrostatic question
   / 4052M Hyrdrostatic question #1
angriffnole
Florida
None
I have been told that with the hydro if you are on a slope moving up or down and you let off the forward or reverse pedal then the unit will stop and not roll back of forth. Is that true with the PowrReverser? For example: will it roll down if you put it in neutral?
   / 4052M Hyrdrostatic question #2
Is the question regards the HST or the PowrReverser?
With HST (at least my 4300), putting in neutral then it will roll. No info regards the PR
Really both: If you have the HST and you are going up a hill then just let off of the peddle will it stop on the hill or will it start rolling back. And from what I have seen the PowrReverser has a forward, neutral, reverse on the steering column that you can use while in gear. If you switch the unit into neutral on the column but leave in gear will it roll back wards or come to a stop. Both examples are with leaving the tractor in gear.
   / 4052M Hyrdrostatic question #4
A hydro will hold on a hill. It may creep slowly, but it won't run away like it would if you put the range selector in neutral. I would still set the parking brake if getting off the tractor.
   / 4052M Hyrdrostatic question #5
Always I'll set the park brake if on any slope at all... too easy to bump the shift lever into neutral and be free wheeling.
Plus the HST loses its "grip" and can coast.
Same with my HST yard tractors.. 455, 425, and X485
got it, thanks guys
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
(2) 3500 LB TRAILER AXLES W/ ELECTRIC BRAKES (A51248)
(2) 3500 LB...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
(8) DRAWER METAL TOOLBOX (A51248)
(8) DRAWER METAL...
