4050 question
/ 4050 question #1
Ben Hucks
John Deere 4050. 6130d
Brand new member here. Needin some good answers. I have a 86 model 4050 John Deere. Tractor has a problem that I hope someone can help with. When the tractor gets hot after you have really worked it it's will not start. It will Turn :)over but will not fire. Starts great when cold or if you just idle around moving hay or something. Doesn't seem to have much blowby and uses no oil. The only thing that I have noticed it that when you put it under a load it blows no black smoke. Any thoughts.
/ 4050 question #2
Th only thing I have heard of is this might be an injection pump issue. That when it gets hot the clearance inside the pump gets to large and it won't start.
/ 4050 question #3
I agree hard(running temp) starting could be inj pump related. It could also be worn bushings in the starter motor or hyd related. If hyd related you could try installing a hyd pump destroking screw part # AR96625 FIELD INSTALLATION KIT, SCREW, HYD ADD 14.44 USD
/ 4050 question #4
Does the engine crank over normal or is it slow when it warm?
/ 4050 question
Yes it turns over a little slower but it just turns over but doesn't fire until it cools down. It has to sit for around an hour or so before it will fire. Tractor seems to be down on power too. I had brakes put on it a few months back and while it was at the dealer I had them put it on the dyno. It peaked at 105 hp but fell of pretty quick when they put a load. I wish I would have had them check the compression. Any ideas after reading this?
/ 4050 question
A little more info. Had some problems with the alternator so I put new batteries and a new alt. I was hoping that was my problem. If the hydraulics are the problem are there any other symptoms that I would see? I have had a lot of problems out of this tractor. I bought if off of tractor house and I believe the guy saw me coming. I have replaced both hydraulic pumps and rebuilt the entire hyd system rebuilt the clutch pack and new brakes. Thats just to mention the big stuff.
/ 4050 question #7
Alot of equipment jockeys on Tractor house. They charge a arm/leg to advert but they do have good coverage. Once you get that 4050 up and runnin it should be a good tractor.:thumbsup:
/ 4050 question
I actually bought it from an individual. He had it posted on there for sale. I love the tractor and have put several hours on it. I think if I can get this fixed it should be real close to 100 percent. I know he had to know the tractor had several problems. Maybe just forgot to mention them.
/ 4050 question #9
sounds like a fuel problem.i would put a new filter on it and check to see if the fuel line has some trash restriction.then check the pump.
/ 4050 question #10
Is it a heat problem or a time problem? If the fuel tank vent is plugged, the vacuum will pull back fuel and starve the motor. After an hour it may have repressurized but siphoned off the pump. Will it fire with starting fluid or not?
how about pulling an injector and watching it pulse.
/ 4050 question
Don't think it is a heat problem gauges never show anything but normal. I have not checked the fuel pressure but have replaced the filter It does have the 466 non turbo motor. I am beginning to think it is a fuel problem as well. Just not seeing any black smoke when it is under a load. It will blow a little when it is cold but still not much. Sure do appreciate the input. Just would like to have an ideas before I head back to the shop.
/ 4050 question #13
I bought a couple similiar machine in past. Not deeres no way but looked good drove good but needed a lot of tlc as they say
Im thinking a drop in power is a big loss of compression.
I would both
check compression
and
then when the tractor is HOT and wont start remove the injectors reconnect to fuel lines and spin the engine full fuel, ether thru the air intake if needed to run it enough to see what blows from the injector holes and the visual injector pattern.
and decide do you love it enough to spend more or pass it on to someone else
/ 4050 question
It says. Sensodyne on the side of the pump. I think thats how you spell it.
/ 4050 question #16
I've heard of a Stanadyne inj pump. After further research in parts cat I found that the 466 could have come equipped with a rotary inj pump. On the rotary type pump the head/rotor can get worn enough to cause hard operating temp. starting. With engine at operating temp before attempting to start pour cold water on inj. pump and then try to crank. If engine starts easier the worn pump is your starting problem.
DISCLAIMER do not put cold water on an inj while engine is running!!!!!!!
/ 4050 question #17
nothing will make sense until you pull the injectors reconnect then and see what is coming out.
/ 4050 question #18
When the engine is running, does it it perform as you would expect. What were the dunk results? Does the engine have any smoke while idling or at full throttle with no load.
/ 4050 question #19
do you have any smoke while cranking? Do you have mechanical of electrical shut down? You can crack the injection line while cranking to see the fuel flow at the injectors without pulling injectors. If it is electrical shut down you could have a fuel solenoid problem that gets weak when it is warm and not turn the fuel on
/ 4050 question
It is mechanical shutdown. There is some smoke after cranking when it is cold after that there is none even under a load. That lead me to believe that it is fuel.
2016 PETERBILT 567 TRI AXLE ROLLOFF TRUCK (A67714)
2016 PETERBILT 567...
2013 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2013 ALLMAND...
2017 GENIE GTH-844 TELESCOPIC FORKLIFT (A65056)
2017 GENIE GTH-844...
2018 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
2014 MAGNUM FRAC MANIFOLD TRAILER (A67714)
2014 MAGNUM FRAC...
FUEL TANK TOOLBOX (A68842)
FUEL TANK TOOLBOX...
