4035 Ground Clearance
/ 4035 Ground Clearance #1
lantxinNETX
NE Texas
Kubota BX23S
Does anyone happen to know what the ground clearance is for a 4035HST? Mine is 100 miles away or I would just go an measure it. I don't see this number on any of the Mahindra info on line. What I am really wanting to do is to place a 5 gallon bucket under the tractor for changing the oil and hydraulic fluid.
Thanks!
Martin
/ 4035 Ground Clearance #2
I think it will fit if you jack it up and put it on jack stands. Otherwise, I'd guess it won't fit. I don't know why Mahindra doesn't include ground clearance in their specs. They did at one time. Hopefully an owner will answer your question. I don't think very many tractors in this category allow enough clearance to get a 5 gal. bucket under them.
/ 4035 Ground Clearance #4
You can cut plastic pail down ' fairly easily ' ... to lower their height. I have a 5035, which has larger tires, and the full size buckets fit under it. Another trick, is to take some scrap two by whatevers with you and drive up on a layer of them to raise your vehicle height.. as high as you need it. Be warned though, you are going to need three pails, a little over 10 gallons of fluid in there. Lay a big piece of scrap cardboard down under the drain and line up your buckets before you attempt to open the drain. Open it up and get ready to slide an empty pail under it fast, rinse and repeat... That's the easy part, the hard part is getting it filled back up with fluid using that little gauge hole in the rear.... Takes a while.... :)
PS: If you look around after you get the fluid out, you will see that there are three or four of them magnet drain plugs on various spots on the sump and transmission. You should take them all out and clean off the magnets on the first hyd oil change... They all are the same 1/2" NPT square drive plugs....
/ 4035 Ground Clearance #5
You will want a pan/pans to change the fluid with. Makes life a lot easier with the 35 series
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
Kubota MX5400 land mgmt package
Kubota MX5400 land...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
2017 Ford Escape (A61569)
2017 Ford Escape...
2008 VOLVO VNL64T T/A 6X4 SLEEPER TRUCK TRACTOR (A59908)
2008 VOLVO VNL64T...
