4030 John Deere oil leak
   / 4030 John Deere oil leak #1
hunter1464
hays, ks
john deere
I do not have a shop manual for this tractor. It has developed an oil leak on the base where the oil filter screws on. There are two metal oil lines about the size of a penny that run into the base of the oil filter housing. The lower line is leaking where it joins the base. Due these lines screw into the base or is there just some O rings where it slides in ? Any help appreciated.
Thank you
   / 4030 John Deere oil leak #2
R22104_________UN01JAN94.gifThere are orings where lines slide in. I am assuming you have earlier style like diagram. Later style did not have oil lines, only coolant. Part number is T13119.
Thank you very much jd. Much appreciated.
   / 4030 John Deere oil leak #4
anyone know if that line screws or slides in and out or special tools required thanks
   / 4030 John Deere oil leak #6
Lubrication of tubes helps not to damage the o-rings.
2022 Club Car Tempo Cart (A51694)
2022 Club Car...
2025 SDLANCH SDLE18P UNUSED Mini Excavator (A53117)
2025 SDLANCH...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2011 Ford F-350 Knapheide Stakebed Truck (A52377)
2011 Ford F-350...
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
2013 Husqvarna YTH18542 42in Riding Mower (A51694)
2013 Husqvarna...
