4025 stability
/ 4025 stability #1
Kirby Nance
Marine, Illinois
1952 8N and 2008 Mahindra 4025
Hi all,
I have a 4025 with no fluid in the tires. Can someone give me an idea where the tip over point might be. In degrees if you could or a general idea if not. Will it go where my 8n will go?
I was just out mowing by my pond and I avoided the more inclined areas where I took the 8n. I think I may just be overly cautious but better paranoid than drowned, right?
Any ideas are appreciated.
Kirby
/ 4025 stability #2
My 3525 w/o front end loader easily goes where my 2n goes and many more places due to traction, it seems scarier because you sit higher but the footprint is almost identical.
/ 4025 stability #3
A lot of this will depend on how far out you have your tires. I think I'd always feel a bit safer with a newer machine since the brakes and power are greatly improved. Not to mention that wierd ROPS thing they put on tractors these days :).
Each situation is different. I don't think you'll find a golden tip over rule. Terrain and soil types and ruts etc will all be factors.
/ 4025 stability
Thanks guys,
It is good to know that it will keep up and surpass the N ford in where it can go. I guess what I wanted was that all things being equal would the N and the 4025 behave the same. The answers helped.
I called my dealer and he said 12 to 15 degrees max on a good surface.
Tim, you are exactly right in that the increased height of the seat exaggerates the fear factor. It looks alot worse than it is.
Well, out to mow...I mean play.
Kirby
CATERPILLAR D3GXL CRAWLER DOZER (A65053)
CATERPILLAR D3GXL...
New/Unused ATS 40 Gallon 2 Stage Air Compressor (A65583)
New/Unused ATS 40...
2010 Workhorse Custom Chassis W62 Delivery Truck with Liftgate (A64556)
2010 Workhorse...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
2250' of 5" Tile (A66408)
2250' of 5" Tile...
Landhonor 65' Extension Cord Reel (A66408)
Landhonor 65'...
