4025 Engine oil dip stick
/ 4025 Engine oil dip stick #1
burzynsr
Grimes county Texas
Mahindra 4025 / Kubota RTV500 / Bad Boy ZT Elite 60"
Went to check the engine oil after greasing the entire machine and pulled out the handle without the dip stick attached. First question is has this ever happened to anyone? I know the dip stick is in the oil pan but don't have a clue when it broke off. I had probably run about 10+ hours since the last oil check I have already purchased the new one from the dealer. Next question or concern, I do not want to drop the oil pan to get it out. Is it possible it could damage something really expensive? Like the crankshaft, connecting rod or oil pump or anything else for that matter? I have access to a "snake camera" that I can borrow from work and I am pretty sure I can get it through the drain plug and see if I can locate it. Any suggestions or advice would be appreciated. Also if you have a 4025 look at the dip stick and see if you think the dip stick bonding to the handle (brazed) seems "cheap" to you. I am leaning toward the cheap on that one.
/ 4025 Engine oil dip stick #2
Most of the time the dipstick tube is just pressed into the block. I’d try and wiggle that out and hope the stick is stuck in the tube.
As far as damage- impossible to say. Anything in the block or pan isn’t good. But playing the odds on that one seems like high risk, low reward....an oil pan R&R vs major damage.....well let’s just hope it comes out with the dipstick tube!!
2023 CATERPILLAR 259D3 SKID STEER (A65056)
2023 CATERPILLAR...
2013 APPCO T-BELT TRAILER (A67714)
2013 APPCO T-BELT...
SCHEDULE 80 PIPING ON PALLET (A67714)
SCHEDULE 80 PIPING...
2019 CATERPILLER 249D SKID STEER (A65056)
2019 CATERPILLER...
2018 Dodge Charger Sedan (A66738)
2018 Dodge Charger...
2017 Nissan Titan 4x4 Pickup Truck (A66736)
2017 Nissan Titan...
