4025 4WD sliding or constant mesh transmission?
   / 4025 4WD sliding or constant mesh transmission? #41
I don't have electrics in the garage yet but I do plan to put in a sub-panel sometime in the future. The garage is about 100' from the house....uh-oh.. guess I'll need that backhoe attachment now. :D
My guess is an after market block heater might help some with cold starts but if not maybe a space heater ? ....jeez...now i have to think about putting up a ceiling :laughing:
I was at a local auction two weeks ago. A nice 3pt backhoe attachment went for $1300. I thought of bidding on it. I also need to run electric out to my barn.
BTW two sickle mowers sold. A NH brand for $1250 and a JD which looked very heavy duty, like it was off a good size tractor, sold for around $650 +or-. Both looked in VG condition.
This winter do some tractor shopping, on a cold day, and see how well they start after sitting outside. My Bobcat w/ a Kubota motor starts right up in the cold. My NH TC40D needed glow plugs in the summer. A good tractor in Florida isn't always good for Maine.
   / 4025 4WD sliding or constant mesh transmission? #42
The 4025 is indeed a compact utility, but I don't know if it's the best of both worlds. Compacts, CUTS, and Utilities all have their strong and weak points. Unless you need to work in confined areas, like I do, Utility size gives you more bang for the buck than a CUT in the same HP range. I think of CUTS more like mid size PU trucks. They are easier to park, but won't do what a full size will do.
Good Answer!!!
   / 4025 4WD sliding or constant mesh transmission? #43
I thought bout the backhoe attachment, but for the price you can get a used mini excavator that is actually used for doing just that. THe whole 3point backhoe breakin the tranny/rearend thing freaks me out.
   / 4025 4WD sliding or constant mesh transmission? #44
As far a cold starts is concerned, for the most part if you keep it inside out of the wind it should start if you have a good battery.
   / 4025 4WD sliding or constant mesh transmission? #46
Under 5 deg. left outside, I would recommend a block heater.
   / 4025 4WD sliding or constant mesh transmission? #47
Do Mahindra Tractors have glow plugs, or any type of cold start aid, besides a block heater?
   / 4025 4WD sliding or constant mesh transmission? #48
Some models have glow plugs, and others have intake heaters.
KMC 4R STRIP TILL (A52708)
KMC 4R STRIP TILL...
Honda ES 6500 Generator (A55973)
Honda ES 6500...
JOHN BLUE 1000 GALLON NURSE TANK (A52708)
JOHN BLUE 1000...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
APPROX. 100 GALLON TOTE W/ ANTIFREEZE (A52708)
APPROX. 100 GALLON...
