4025 4wd max disc harrow size
   / 4025 4wd max disc harrow size #1
TXMike06
Dayton, TX
Mahindra 4025 4wd
I have a 4025 4wd with a loader that I'm wondering of I can pull a 8' 24 blade disc with. Im not sure how tall the discs are but they are notched and the whole disc is supposed to be about 1100lbs. Id like to able to run it offset as well to really churn up some soil I havent disced up already. My soil is sandy loam and Im planting some sprigs next month and want to upgrade from the 5' disc I borrowed from a friend. Thanks.
   / 4025 4wd max disc harrow size #2
From your description you are likely looking at a 24/20" or 24/24" Tandem Disc Harrow. You will be able to pull either size behind your Mahindra 4025/4-WD. A 24/20" Tandem Disc Harrow, in theory, should till 9" deep after several passes over the field; probably 7-1/2" in the real world. A 24/24" Tandem Disc Harrow will till slightly deeper.
Disc Harrows of this pan diameter USUALLY have 9" spacing between pans and USUALLY have Category I/II hitch compatibility.
Following link should help you to make an informed decision once you have determined actual pan diameters and pan spacing:
http://www.tractorbynet.com/forums/attachments/308251-disc-harrow-selection-18-45-a.html
2012 BMW 528i AWD Sedan (A50324)
2012 BMW 528i AWD...
Charlotte County (A50323)
Charlotte County...
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
2010 Lincoln MKS Sedan (A50324)
2010 Lincoln MKS...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2019 Nissan Sentra Sedan (A50324)
2019 Nissan Sentra...
