4020 where is hydraulic filter?
   / 4020 where is hydraulic filter? #1
Amherst Wisconsin
Ford 641 / 1963 Fordson Super Major
I have the filter. Not sure where this filter is at?
Can anyone give me a pic of its location?
Also was told there is a screen behind a plug ? Is there a pic where this is?
And lastly is there a fuel shutoff on the tank? To change filters?
Thanks Ty
   / 4020 where is hydraulic filter? #2
Maybe more info on tractor (tranny type - fuel type - serial number for break)
Hyd. filter schematic that may help. Can see key #23 for the screen.
You can find same at jdparts.com (free registration)
Fuel tank shutoff at bottom of tank.
   / 4020 where is hydraulic filter? #3
Thanks Ty
Filter cover is round with bolt in center located on LH(drivers) side. Screen plug is marked. What type trans does your tractor have(PS or Syncro) PS has 2 filters as per beenthere's schematic. Syncro-range has 1 filter. Yes there's a fuel shutoff in bottom of tank accessed in front of frt axle
Serial number is:
T213R 149610R
Thanks guys.
I am assuming the hydraulic filter base is in the pic with the screen you have noted?
Large round with the center nut?
And fluid must be drained to change filter?
any maintenance recommended on the air cleaner - oil bath on this tractor?
   / 4020 where is hydraulic filter? #7
Filter can be changed without draining hyd oil. Clean dirt out of air cleaner cup and refill with engine oil to full line in cup. Filter cover is round with bolt in center located on LH(drivers) side.
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
2016 Isuzu NPR Landscape Dump Truck (A51691)
2016 Isuzu NPR...
Fork Attachment (A51691)
Fork Attachment...
45050 (A51694)
45050 (A51694)
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
