4020 voltage, 1971 diesel
   / 4020 voltage, 1971 diesel #1
ARAYT
Middle Ga
Ford 1700, Ford 750 TLB, Case 585
Can someone tell me if the 4020 ever came wired as a 6 volt system? I have a friend that is trying to get his up and running and he thinks it was wired as a 6 volt system. It has 2 each 6 volts batteries but he thinks they are/ were wired parallel. He said the neg is connected to frame and from there not sure. Appreciate the help.
Thanks Ray
   / 4020 voltage, 1971 diesel #2
Yes, the 4020 came with 2 6V batteries wired in series. Everybody I know replaces them with 2 12V batteries wired in parallel. Plus we used to occasionally throw 24V at it to start using a battery cable double knife switch to cross over the main hot wire. It's not as bad as it sounds because the cables attenuate the power supplied. Fast start, eh ?
   / 4020 voltage, 1971 diesel #3
Ditto '69-'72 4020 came from factory with 2 six volt batteries wired in series for 12 volts. JD decided on 55 series rowcrop tractors that two 12 volts batteries wired in parallel is better than two 6 volt in series & I agree.
I've owned a JD 4255 since Feb. '93. WOW that will be 30 yrs in a couple of weeks.
Tell your friend to check relay mounted on firewall above starter utilized to send extra amps to starter solenoid start terminal to be sure it's receiving a ""good ground connection""".
Thanks for the reply zzvyb6. I'm aware of the 6v batteries but did any come wired in parallel, a true 6 volt system?
Thanks Ray
Thanks TX Tim, Will check the ground. I guess we were typing at the same time, please disregard the previous question unless there's more info. Thanks Again!
Ray
   / 4020 voltage, 1971 diesel #6
You're welcome. The last JD rowcrop with 6 volt system was late 1940's.
John Deere 652R (A50121)
John Deere 652R...
2017 Ford Explorer SUV (A50324)
2017 Ford Explorer...
2016 Ford Focus SE Sedan (A51694)
2016 Ford Focus SE...
1972 Baker 30ft Pole S/A Towable Trailer (A51692)
1972 Baker 30ft...
2017 Ford F-450 XL (A50120)
2017 Ford F-450 XL...
2016 Chrysler 200 Sedan (A50324)
2016 Chrysler 200...
