4000 Ten Hydraulics
/ 4000 Ten Hydraulics #1
StanInCalif
Northern Sacramento Valley, Calif.
JD 300B, JD 4310
This is what you get if you order all the hydraulics offered. The lever between the joystick and rockshaft lever is the 3rd scv and operates the clamshell on the 4-in-1 or a cylinder on rear implement. The rocker switch diverts fluid from front to rear and operates 4th and 5th scv's for top and tilt, using the joystick.
In the second photo, from left to right; At far left and first one in horizontal bank of five is power beyond. Remaining four are top and tilt. Bottom two vertically at right are 3rd scv.
/ 4000 Ten Hydraulics #2
Maybe it's because it's late here, and my eyeballs are mostly closed, but I only get a little slice of the control panel and part of a round knobbed lever when I open the attachement.
/ 4000 Ten Hydraulics #4
Hey Stan, I THINK I see evidence that you got Yours! Way to Go!
Second attempt
/ 4000 Ten Hydraulics #7
Stan,
I'm just glad to see another tractor with some dust on it. I thought my land was the place where everyone's dust settled(especially on my tractor).
Thanks for the photos...Kyle
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
2017 Mack Semi (A64047)
2017 Mack Semi...
SCAN TO RECEIVE TEXT UPDATES (A64276)
SCAN TO RECEIVE...
John Deere 50 (A60462)
UNUSED WOLVERINE HYD MINI 4IN1 BUCKET (A64281)
UNUSED WOLVERINE...
(APPROX. 34) 2X6X10.5 ROUGH SAWN OAK (A64276)
(APPROX. 34)...
