400 hr. Hydro Oil Change Advice???
   / 400 hr. Hydro Oil Change Advice??? #1
nickmags
Gainesville, MO
Kubota L4701
The Super UDT in my L4701DT (shuttle shift) looks like brand new. Can I just replace the filter and what oil is lost with that, rather than all 10 gallons of liquid gold super UDT2 without damaging anything? Retired on fixed income. SuperUDT2 is crazy expensive for 10 gallons. ($235+ for 5 gallon bucket) On the other side, I don't want to damage anything. Just seems an unnecessary expense. Please, no lectures on " as little as you use it, okay" I know that one. Constructive advice!
   / 400 hr. Hydro Oil Change Advice??? #2
Do you know if the oil has ever gotten real hot vs normal operating temperature? If never been hot and no water intrusion I would be less concerned about changing the oil since heat and moisture are what kills oil.
Other considerations is how is this used. Occasionally worked hard or worked hard for hours every day. Again hard for hours everyday day I would consider changing fluid but occasionally would be less likely to change fluid.
Bottom line is what does your gut instinct say vs the wallet.
Hydro has never gotten hot. Tractor seldom gets more than an hour of work at any given instance. Hand testing line and actuators, warm after use but nowhere near hot, let alone overheated.
   / 400 hr. Hydro Oil Change Advice??? #5
I would run it, as long as there is no water contaminants. I'm at 500 hour on the fluid of my tractor and won't plan changing until 600 or 700 hours.
When I changed my hydraulic filter at 300 hours, I drained everything out, then changed the filter and put it back in but used a really fine mesh material on the filter so it went back in somewhat filtered.
   / 400 hr. Hydro Oil Change Advice??? #6
If the hydro oil was not changed at the 50h interval, I would change it now at 400h.
I changed my current Kubota hydro oil at 400h, and 1200h. My previous Kubota got a 50h change, then every 800h. The last hydro oil change I experimented with 3x the interval with sub micron filtration, and I noticed performance issues and noise.
Extending intervals is certainly doable depending on a variety of factors, but you can't go wrong with following the manufacturers recommendations.
   / 400 hr. Hydro Oil Change Advice??? #7
With hydraulic fluid, looks can be deceiving. It might look fine and be clear but it's the additive package in it that gets depleted and necessitates a change.
I don't run SUDT in either of my Kubota's for a couple reasons, mainly the difficulty of actually determining the correct level of it as it's hard to see on a dipstick or even in a sight glass (both mine have dipsticks). I run Chevron THF synthetic fluid. It's a bout the same prices as SUDT, meets and exceeds the Kubota specs for SUDT but has one big positive aspect and that is, it comes pre dyed orange of all things so it's easy to see on a dipstick or in a sight glass. I use 85-140 in the front axles however, not hydraulic fluid.
My manual only calls for 50 hour hydro change on HST models. DT shuttle shift first change is at 400 hrs. My thought was change the filter at 400, then filter and oil at 800 or sooner if I noticed oil getting dark. Again I don't want to do damage, but nearly $600 for an oil change is excessively hard on my budget.
   / 400 hr. Hydro Oil Change Advice??? #9
My advice - bite the bullet and change the oil and filters. Hydro oil will never get dark unless something catastrophic happens. As previously stated, the additive package has a finite lifespan. I'm sure you could get another 100 hours out of it, but why not follow the Kubota maintenance schedule? Their engineers are smarter than the average user.
   / 400 hr. Hydro Oil Change Advice??? #10
Parker 400 bu Gravity Wagon (A50515)
Parker 400 bu...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
2025 JMR 40in Single Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A50322)
2025 JMR 40in...
2015 Hyundai Sonata Hybrid Sedan (A50324)
2015 Hyundai...
4' x 6' Tilt Trailer (A50515)
4' x 6' Tilt...
2019 Freightliner Sprinter 1500 Van (A50323)
2019 Freightliner...
