4 x 24 Prince tie-rod cylinder
   / 4 x 24 Prince tie-rod cylinder #1
jawz41
At Northern the price was $113 on sale, normal retail was $289. They are not going to carry them anymore, slow mover. Had to buy it like I need another project (like log splitter). So I bought it. Can someone give more ideas to use this cylinder for other project? Would be nice to use it for more than just a log spiltter.
   / 4 x 24 Prince tie-rod cylinder #2
Well, a 4" cylinder with 1 3/4" rod at 2500psi has 31,416 lbs of push and 25,403lbs of pull ( 2000psi would give you about 25,000/20,000 respectively)so you could make some BIG projects. Dump wagon, rock crusher, trash compactor, tree shear, mother-in-law lift.
A cylinder that size takes a lot of GPM to cycle quickly too. 10 GPM would take 14 seconds to fully cycle (extend/retract 24" each way) it so that is always something to consider when putting a project together.
Personally, I think a tree shear might be handy but don't think 24" stroke would be necessary.
   / 4 x 24 Prince tie-rod cylinder #4
Hey Jawz, I see your post was from mid april, but how long ago did you make that purchase from northern? Was it through the hotline catalog or just the regular one? Thats a good deal and i'd like to jump on it, but i can't find it online. Thanks.
It was in the store on the discount rack. They said that it was going to be discontinued.
   / 4 x 24 Prince tie-rod cylinder #6
Build a shearer with a 4:1 leverage to cut 6"......at 4 times the cylinder force....or 3:1 leverage to cut 8" at 3 times the the cylinder force.....
build it adjustable??
and the same cylinder could be used for many applications, removeable clevis pins, and QD's on the hoses.....:thumbsup:
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2015 HINO XJC740 BOX TRUCK (A53426)
2015 HINO XJC740...
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A53473)
NEW 2024 LOAD...
