M59
Platinum Member
- Joined
- Oct 27, 2014
- Messages
- 557
- Location
- Fairview NC
- Tractor
- Kubota M59 TLB/ Mahindra Max 24 TLB/ KX-080-5
I maintain a longer driveway ( 3/4 mile ) consisting of stone and many sections have a steeper rise than what I see in your picture. This driveway stands up even in torrential rain because it both porous and construction material is too heavy and too well locked together to be moved by water.
The base is always silt fabric ( I've used both non woven and woven ) to keep the mud from pumping up into the ballast layer then a layer of railroad ballast ( 4-6" ). This will pack down to a level but fairly porous surface and is too heavy for even torrential rain to move. If you want a smoother surface then add a bit of crushed ( 1-2" ) that will then filter into voids in ballast and tends to lock the stuff even tighter.
I have run heavy equipment of this buildup, including loaded cement mixers, without leaving ruts. Short of dropping your backhoe teeth into this build it will stay in place.
