Traction 4-wheel Drive
   / 4-wheel Drive #1
toneychaney
kioti ck20
I have a Kioti CK20 and It will not go in 4-wheel drive at times and others times it will not stay in 4-wheel drive, can someone help with this problem? I tried to use the bucket and raise it up and then try to get it in 4-wheel drive but that does not work, at times it will go in 4-wheel drive when it is in the HI gear but won't when its in LOW gear with it not going in 4-wheel drive there is a lot of things I am unable to do with the attachments, Please help.
toneychaney@comcast.net
   / 4-wheel Drive #2
I believe that the 4wd lever is mounted on the same shaft as the High-Low shifter. You need to lubricate all the linkage as well as the pivot points on the shaft..
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
377811 (A48836)
377811 (A48836)
2017 John Deere HPX615E Gator Utility Cart (A51691)
2017 John Deere...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
2020 KENWORTH T680 (A52472)
2020 KENWORTH T680...
2023 LMC M40018 LOT NUMBER 176 (A53084)
2023 LMC M40018...
