4 Wheel Drive Difficult to Change to 2 Wheel
   / 4 Wheel Drive Difficult to Change to 2 Wheel #11
</font><font color="blue" class="small">( I finally go around to trying the suggested solutions to the 4 wheel drive engaement/disengagement. Lifted the front wheels off the ground with the FEL and PRESTO the lever was easy to pull. Thanks for the suggestions.
/forums/images/graemlins/grin.gif
J D )</font>
mine does the same thing, i'll have to give that a try.
i usually put the tractor in first gear high range and pull up on the lever while driving and letting off the accelerator
   / 4 Wheel Drive Difficult to Change to 2 Wheel #12
</font><font color="blue" class="small">( i usually put the tractor in first gear high range and pull up on the lever while driving and letting off the accelerator )</font>
Most manuals that I have read suggest that the clutch be pushed in, the tractor stopped before going from 2WD to 4WD though. I don't think there's a problem doing that from 4 to 2, but you may break something going the other way. Safest and easiest on the tractor to just stop first. John
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
550 GALLON FLAT BOTTOM POLY TANK (A58374)
550 GALLON FLAT...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2014 FREIGHTLINER  CASCADIA (INOPERABLE) (A58214)
2014 FREIGHTLINER...
Service Truck Hydraulic Rear Liftgate (A55787)
Service Truck...
10,000 PSI AIR HYDRAULIC PUMP (A58216)
10,000 PSI AIR...
