4 wd
maple crest
shrewsbury vt.
ih 806,kubota6950&241dt same60
got a case 1494 4wd. the 4wd acts funny. the front out pulls the rear until you step on rear lock lever. then the rear and front turn at the same pace. is this the normal way this tractor should pull in 4 wheel drive?
/ 4 wd #2
I perfer to see front end lead between two and five percent! Any more and you are just spinning tires and any less and the rear will be pushing the front in turns.
Different tire swaps could make the front lead too much or it could be too slow.
/ 4 wd #3
The rear lock lever shouldn't cause the front and rear axles to travel at the same pace What does it do when you drive in 2wd? If it drives fine in 2wd with or without the diff lock engaged, then I haven't a clue what would cause this. If it only drives in 2wd with the diff lock engaged, it sounds like a broken axle or something.
SQUARE FUEL TANP & HAND PUMP (A63291)
SQUARE FUEL TANP &...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
karcher pressure washer (A61567)
karcher pressure...
Tufline Box Blade (A64047)
Tufline Box Blade...
2021 PETERBILT 367 (A63569)
2021 PETERBILT 367...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
