Loader 4-way valve hook up FEL
   / 4-way valve hook up FEL #1
jam2004
central NJ
Kubota BX 2230
Had to switch from three-way to four-way valve on bx2230 to work snowthrower. I want to attach my FEL but I'm not sure which valves/hoses connect to the corresponding hoses on LA 211 loader. I've seen the new bx's and wish my hook ups were so neat and easy. Can someone help me with this one? Last time I did it, loader would raise, but bucket wouldn't move, then vice-versa. Color coded hoses are not consistent with their coupling mates.
   / 4-way valve hook up FEL #2
If you post a picture of the valve, and trace the lines from the cylinders to identify the lift/lower and dump/curl we can help.
Will do. Thanks.
Bush Hog 10' Pull Rotary Mower (A50774)
Bush Hog 10' Pull...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A50323)
2012 Mack CXU613...
18007 (A51691)
18007 (A51691)
CATERPILLAR LOADER ATTACHMENT (A51243)
CATERPILLAR LOADER...
2014 Ford F-550 Altec Bucket Truck (A50323)
2014 Ford F-550...
2019 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2019 CATERPILLAR...
