4 way bucket recommendations for Kioti CK30
   / 4 way bucket recommendations for Kioti CK30 #1
TDMLLC
Kioti CK30
Hello,
New to the forum. How can I figure out if I can add, or what would it take to add a 4 way ( 4 in 1 ) bucket to a 2006 Kioti CK30? Also, any recommendations on manufacturers, or where to buy?
Thanks!
   / 4 way bucket recommendations for Kioti CK30 #2
If your tractor has a skidsteer quick attach there will be several options for 4in1 buckets. However you will need to be careful as the lift capacity on a KL130 loader is only 1155 lbs. 4in1 buckets are significantly heavier than regular buckets because of the bottom lip being very thick because it lacks the support that the back of the bucket gives a normal bucket bottom. I do not have a recommendation on brand.
If you have a pin on loader, then I do no know of anyone making a bucket to fit. Your best bet would be to convert the loader to skidsteer quick attach.
What are you intending on using a 4in1 for? I always thought they were neat, until I used one a few times, then I discovered that purpose built attachments generally work better (grapple, regular bucket, blade).
   / 4 way bucket recommendations for Kioti CK30 #3
Video of 4way on a Kioti. Probably doesn't answer the OP's question, however.
2009 Lexus RX 350 SUV (A53424)
2009 Lexus RX 350...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51692)
2013 International...
2012 Chevrolet Cruze Sedan (A53424)
2012 Chevrolet...
1454 (A57192)
1454 (A57192)
(5) Ladders (A56469)
2018 International DuraStar 4300 2,000 Gallon Water Truck (A55852)
2018 International...
