4 Series In The Field
   / 4 Series In The Field #1
mstockdale
New Brunswick, Canada
None
Hello,
I would like to get a 4044r to do some minor haying work (square bale - 15 acres at the most per year) has anyone used a 4 series tractor in this capacity? Would also be looking to use this tractor for various other tasks around my property such as snow removal.....lots of snow removal, bushhogging, landscaping, firewood hauling, loading sawmill etc...
wondering what your experiences have been with your 4 series and do you wish you had gone bigger?
   / 4 Series In The Field #2
Limited response may be that no one else can answer your quest for "a tractor to suit my needs". just sayin.....
Wish you the best, and someone may come along and give you an answer, but it will not be other than what works for "their needs". You'll have to decide if theirs are a match for your needs.
Good luck.. ;)
Good luck.. ;)
Thanks for the input, i certainly struggle with expressing what i mean in written word not a word smith by any stretch. But yes i am looking for how peoples tractors suit 鍍heir needs as their experiences will hopefully guide me in choosing a tractor.
   / 4 Series In The Field #4
I had a 70HP Kubota tractor (kind of a 4 series size?) and replaced it with a bigger 5 series JD. The only thing that I lost was a slight amount of agility in tight forested areas. I only have 50hrs on the new machine and so far it's better for everything, which includes loader work, grapple work, chipping, and feeding round bales. Haying is just around the corner and I can't wait to see how things go.
   / 4 Series In The Field #5
What's the maximum weight of a log that you'll be loading onto the sawmill?
That sounds like the biggest task that you'll be wanting your new tractor to perform.
I found an online calculator that spit me out a number for a Maple log 8" at the small end and 20" at the butt 16' long would weight around 1200lbs (approx.544kg) that would be about the heaviest since I mostly process softwoods (spruce, pine fir).
   / 4 Series In The Field #7
Personally, I'd buy hay before spending 40k ( including tractor ) on equipment to bale 15 acres worth of ground. Every ton of hay you harvest takes roughly 75$ worth of nutrients out of the ground. If you can buy hay for $100 - $125 per ton you are money ahead. I can buy round bales all day long for $90 - $125 per ton.
If you really really want to avoid the rain showers, equipment breakdowns and make your own hay I wouldn't have a machine that is less than 100 PTO HP. My buddy and his dad make hay on my ground and they use a JD 4230 and an IH 880. I have a 60HP Fordson ( 6k lb tractor ) and I don't think it has the weight nor the HP to pull a fully loaded hay wagon and baler, let alone a 12 foot haybine in 3 foot tall grass. If you do get the 4 series tractor and plan on using it to make hay I would not get the hydrostatic model. IMHO hydrostatic tractors are not built to lug like a geared tractor.
   / 4 Series In The Field #8
Sloeffle makes some good points on the economy of baling yourself.
Can you "get away with" a 35 (PTO) hp compact utility tractor on a baler? Eh.. maybe, probably, many have.
The questions are:
How hardened (long term life span) is the pto to take the shock/surging of a baler's plunger? (Dependent on: How big is baler's flywheel, how fast are you feeding hay, type of grass, etc...) Not sure if todays compacts are as hardy as the old Farmall H's or Deere A's of similar horsepower.
Does baler have a kicker or thrower? Are you pulling a wagon? Is terrain flat?
Others may have comments on the pros/cons of smaller windrows (less leaves knocked off / but longer baling time / many bale flakes, etc..)
It's easy to spend other people's money, so the usual advice here is to tell people to buy bigger than what they think they can get away with.
I don't think the 5 series is that much more expensive (if at all) and you get a lot more capacity for other tasks like loading sawmill etc...
Great info thanks...Yes it would be a little foolish to spend 40k on a tractor and hay equipment for 15 acres (My neighbor currently has all the equipment so no need to purchase). Haying will be only a small component of what I will be doing with the tractor but want to make sure the 4044 will do the task....which from my reasearch should not be a problem to run a sickle bar mower, tow a tedder and rake, and run a square baler (we usually pick up the bales by hand...no thrower :thumbdown:).
Might be a better idea to go with a 3 series and find an old David Brown, Ford or something to do the haying with.
Good call on not getting a hydrostatic...I like hydrostatics but prefer the geared power reverser.
No Thrower, would only be pulling a wagon to pick up bales, terrain is gentle slope with a gully at the end.
Haha yes certainly understand...I received a quote on a 5075M from my local dealer for $66,000..approx $825 per mth....a hard one to swallow.
Hammerhead V140 (A50121)
Hammerhead V140...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
John Deere 1770 Conservation 16 Row Planter (A50774)
John Deere 1770...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2012 Dodge Grand Caravan Van (A51694)
2012 Dodge Grand...
Welder (A50121)
Welder (A50121)
