Planters 4 row planter how much hp?
   / 4 row planter how much hp? #11
BayouMan said:
Hey farmwithjunk,
What part of Kentucky are you from. I used to live in Smith Mills, which is about 10 miles southwest of Henderson.
Mount Washington is about halfway between Bardstown and Louisville in the north-central part of the state.
   / 4 row planter how much hp? #12
I use a 855 John Deere and a 4 row 71 flex planter worked fine behind it. I couldn't fill it up with seed, but otherwise. it worked great. I sell these planters on ebay-do a search for corn planter .
You can take a look. The 4 row model with a light duty hitch weighs about 800 lbs, so your Kubota would be able to handle it with no problem and you could add liquid or dry fertilizer.
You are correct that most of the guys I sell planters to, spread dry fertilzer and work it in, as these planter units are not good for no till planting.
1996 FORD F-SERIES FLATBED TRUCK (A57192)
1996 FORD F-SERIES...
2006 Hyundai Sonata Sedan (A55853)
2006 Hyundai...
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
2018 MERTZ MANUFACTURING 2500HP QUINTUPLEX FRAC PUMP (A55745)
2018 MERTZ...
2011 Case IH Steiger 335 AFS Tractor (A53485)
2011 Case IH...
