Rotary Cutter 4" Rotary Cutters that work with iMatch
   / 4" Rotary Cutters that work with iMatch #1
powwowell
Deep Run, NC
John Deere 1026R
I'm shopping for a 4' rotary cutter to use with a JD 1026R. My physical condition requires me to use implements that are compatible with the JD iMatch. Any suggestions from those who have been there?
And,any suggestions for a 4" rotary tiller?
Thanks, Larry
   / 4" Rotary Cutters that work with iMatch #2
I don't remember seeing any 4' cutters that were QH ready. That said, I managed to convert my 4' BushHog.
   / 4" Rotary Cutters that work with iMatch #3
Frontier makes a nice one.
Thanks for the advice. I think I've made my decision.
Larry
   / 4" Rotary Cutters that work with iMatch #5
Larry
Late addition I saw in my travels that I don't have experience with is a King Kutter 4' with Flex hitch. I've seen them iMatch and Quick hitch compatible for as little as $1000 for one with a sheet bolt. Price climbs as you add things like slip clutch.
If you found your dream machine... What did you get? Any pictures?
I will share pictures when I make the purchase.
   / 4" Rotary Cutters that work with iMatch #7
Anticipation....:)
   / 4" Rotary Cutters that work with iMatch #8
The LX-4 was, but I don't recommend it. I do recommend the Frontier. Have had it on the 1025 and the 2025. So much easier to remove the blades because the stump jumper stays in place.
Ralph
   / 4" Rotary Cutters that work with iMatch #9
The thing about rotary cutters is you shouldn't have a rigid top link hookup. It needs to float. I have a Howse (not sure you can get this brand anymore) and the top link hookup has a slot allowing the top link to float. I got a top link quick hitch adapter and it works pretty slick.
A closer look at the adapter hooked up to the top of the iMatch:
Bought a used King Kutter (TG-48-YK) today. It does hook up to the iMatch. I would like to have a manual for it. Willing to pay for one. I was not able to find one on the web. Kept getting I needed to add Google stuff? I assume the tiller has lost some of the gear oil. Looking to pick up a used Kodiak 4 Ft. brush cutter tomorrow. The newer promotions say the Kodiak is Quick Hitch compatible.
2014 INTERNATIONAL MA025 (A52472)
2014 INTERNATIONAL...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
2012 PETERBILT 365(INOPERABLE) (A52472)
2012 PETERBILT...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
